Trying to remove Rear Toe Arm?? HELP!!!
Old Apr 22, 2006 | 10:41 AM
plastiketa's Avatar
plastiketa
Default Trying to remove Rear Toe Arm?? HELP!!!
Hi Everyone,
My car is up on jack as we speak and I'm trying to get the rear toe arms off the car (the rod the running parrallel to the car, slightly in an angle). I remove the bolts attached to the brake assembly, but I cant seem to get to the bolt on the other end.
I tried a search and one other person had the same problem but there was no reply to his post.
Any suggestions?
Thanks in advance!
Old Apr 23, 2006 | 06:08 PM
plastiketa's Avatar
plastiketa
Car is back on its feet but couldn't figure out how to change the toe arms. Still looking for some help though...
Old Apr 24, 2006 | 02:39 PM
Auto RnD's Avatar
Auto RnD
you get it off unbolt it its bolted to subframe and knuckle..
not too hard to do =)
Old Apr 25, 2006 | 09:45 AM
plastiketa's Avatar
plastiketa
The bolt on the subframe would not budge! I was even using a 90psi impact wrench! I may just have to get a shop to put them in. Most likely West End Alignment down here in Torrence. THey do some great work from what I'm told.
Old Apr 25, 2006 | 09:57 AM
~~O8>'s Avatar
~~O8>
Try spraying it with some WD-40 (let it sit for a few minutes) and smack it a few times with a rubber mallet, then go at it with the impact wrench. Mine came off fairly easily with a power impact and some elbow grease.
WestEnd is a good option as well, Darren does very professional work, I got some suspension work and alignments from him. Its not cheap but guaranteed to be done right and clean (don't have to worry about dings and scratches to your car or rims).
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
