To those with Nismo S-Tunes
Old Jun 29, 2006 | 12:04 PM
Rog1206's Avatar
Rog1206
Default To those with Nismo S-Tunes
I just purchased a set and it won't be here for a while but I was wondering if they come with strut tops and the rest of the hardware such as bump stops, washers, etc? Since I don't have my stock suspension anymore, I might have to buy a set of strut tops.
Thanks
-Roger
Old Jun 30, 2006 | 01:33 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Thanks
-Roger
Yes you will need to replace them. You can find them here at www.performancenissanfactoryparts.com
Old Jul 1, 2006 | 11:22 AM
Art Vandaleigh's Avatar
Art Vandaleigh
May be a dumb question, but if you are in fact replacing the stock suspension with the s-tune, does the s-tune come with all the hardware for a direct swap?
Old Jul 2, 2006 | 04:33 PM
RedBird's Avatar
RedBird
Bump
Old Jul 2, 2006 | 04:57 PM
Z CRUZN's Avatar
Z CRUZN
Yes, it comes complete for a direct swap.........
Old Jul 2, 2006 | 05:32 PM
islandsnow's Avatar
islandsnow
yeah, they swap right in. They aren't just the lower strut, it's the whole strut with spring and top, they just bolt right in. Now if you don't have the bolts or screws that hold them in, then that's another thing, you will have to order them. The rears are the 2 shocks and 2 springs, the fronts are 2 complete struts. I'm not sure what you're talking about stops, but you should have the stock stops still installed, unless someone took them out??
Old Jul 2, 2006 | 07:42 PM
1cockyZ's Avatar
1cockyZ
I know this is off topic but can someone with s tunes please pm me the thread size of the rear shock top i want to replace my jic pillowballs with something quieter.
Old Jul 3, 2006 | 11:29 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
they come with everything you need except the rear shock upper mounts...
the front shock / spring assembly is fully assembled...
If you do not have your rear upper and lower rubber spring seats you will need them as well....
Pillow ball mounts will be louder then the OE mounts which are alreay pretty rigid in the rear... wouldnt be much of an upgrade going to pillow mounts....
Old Jul 5, 2006 | 02:17 PM
Rog1206's Avatar
Rog1206
I sold my stock suspension since the Tein Flex came with everything I needed. If the Nismo fronts are fully assembled, then it looks like I only need the rear upper strut mounts. Do you have a link to them on your site Jason?
-Rog
Old Jul 5, 2006 | 02:22 PM
Jason@Performance
Performance Nissan
for the rear upper mounts you will need this list of parts...
2 of everything unless otherwise noted:
put the part numbers in on this page:
http://www.trademotion.com/partlocat...&siteid=214252
55322AL500
552482Y000
55240CF40A
56218AG000
089183081A (4 required)
55323AR000
55338AL500
56217AM001
552694U000
Old Jul 5, 2006 | 03:58 PM
Art Vandaleigh
Ok so if you are doing a direct swap from the stock suspension to s-tune, you wont need those parts, unless you dont have the stock suspension pieces. Just want to make sure if i order it, i have all the hardware.
Old Jul 5, 2006 | 04:06 PM
Jason@Performance
Performance Nissan
Correct, if you are putting S-Tune on a stock suspension you will not need those...
The above parts are all of the parts required if they are missing... that includes hardware, paper gasket, stopper, boot, nuts
this does NOT include the upper and lower rubber spring seats...
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
