Springs vs. Coilovers
Old Aug 7, 2006 | 11:17 AM
showbizz_41's Avatar
showbizz_41
Default Springs vs. Coilovers
Which is more worthwhile.. Springs, being that they are relatively cheap, or going the extra mile onto coilovers? Taking into consideration ride height and overall performance of course!
Old Aug 7, 2006 | 11:24 AM
sen_jen's Avatar
sen_jen
i think you just answered your own ?uestion, no?
Old Aug 7, 2006 | 11:26 AM
showbizz_41
Im just looking for some input on weather or not the extra cash is worth while.
Old Aug 7, 2006 | 11:27 AM
showbizz_41
What suspension work do you have done?
drunkin master's Avatar
drunkin master
If you are not going to track I don't see spending the money to get a coilover set. For dd springs and maybe an upgrade on your shocks should be fine.
Old Aug 7, 2006 | 11:31 AM
showbizz_41
Who has had driving experience on both spring sets and coilovers on their Z's or someone elses?
Old Aug 7, 2006 | 12:54 PM
sen_jen's Avatar
sen_jen
well, the extra cash is worthwhile for coilovers. why? some reasons are of course because of the height adjustment. you'll always encounter spots where you just can't clear. it's good to have a quick fix for this. stock shocks are good for only so long. with the coilover, it's already tuned/matched to the springs so you'll be able to run them a lot longer than springs over oems. however, as others mentioned, you can purchase aftermarket shocks to go along with the springs. the pricing can exceed a normal coilover though.
what are you planning to do with the z? regular driving with the occassional spirited driving, track, race??
Old Aug 7, 2006 | 12:58 PM
showbizz_41
Yea, mostly street driving. Turbo it and then run it at the track, put down some quarter times and then back to the street... Which is why im leaning towards a spring set, or perhaps the tein basics
Old Aug 7, 2006 | 02:11 PM
sen_jen's Avatar
sen_jen
^ if you're gonna boost it, run coilovers. forget springs.
Old Aug 7, 2006 | 02:30 PM
636Racer's Avatar
636Racer
air bags.
Old Aug 7, 2006 | 02:36 PM
betamotorsports's Avatar
betamotorsports
IMHO, unless you're competing at the upper levels of autocross or amateur racing, coil overs won't give you anything over Nismo's T2 race spring and shock setup. In most cases, there are very, very few drivers skilled enough to need something more then the T2 suspension.
Old Aug 7, 2006 | 05:41 PM
WA2GOOD's Avatar
WA2GOOD
Hahaha, Ummm, I have. A lot of daily driving and a lot of track days with both coilovers, and spring / shock combonation.
Old Aug 7, 2006 | 05:45 PM
VN_350z's Avatar
VN_350z
I am thinking of getting tein coilover. I debate between basic or flex. I won't use EDFC and i won't track the car.Which one should I get>
Old Aug 7, 2006 | 07:02 PM
sen_jen's Avatar
sen_jen
neither. go with Stance Coilovers instead. very good overall purchase. you will not be upset. cheaper than Teins, better imo, and they're monotube. yes, the new Flex's are monotube as well, but more expensive, and have less height adjustments.
Old Aug 7, 2006 | 08:46 PM
VN_350z's Avatar
VN_350z
i never heard of stance coilovers.
Old Aug 8, 2006 | 03:39 AM
SilverJDMCoupe's Avatar
SilverJDMCoupe
For a I think around the same price or a little lower than the Tein their are the Tanabe Coilovers. The Sevens they have are priced higher than the Tein Basics, but the S-OCs are priced comparable, if not less expensive. If you go with springs, there are going to be more than a couple of times your gonna wish you could lower the car a little bit more, or raise it a little bit more, coilovers in general are well worth it!
Old Aug 16, 2006 | 06:25 AM
mberthia's Avatar
mberthia
Where can I get more information/purchase the T2 springs ?
Old Aug 16, 2006 | 06:27 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
We have them in stock.... http://www.mynismo.com/products/?id=2792
Old Aug 16, 2006 | 06:39 AM
mberthia's Avatar
mberthia
Originally Posted by Andy@Performance
That was a fast response! At 690lbs, these must not be streetable right ?
How much do they lower the vehicle?
Old Aug 16, 2006 | 06:46 AM
plumpzz's Avatar
plumpzz
Damn that must be stiff as hell. Im guessing minimal drop?
