tein S/H tech
Old Aug 17, 2006 | 10:30 PM
norapat01's Avatar
norapat01
Default tein S/H tech
Just got a simple question...I wanna lower my car so can't decide between tein S tech or H tech. Anyway, it said that both are decide to use with OEM/OEM replacement shocks. So those of you who got these spring install on their Z, do you have any problem with the VDC or getting the alignment done at the dealer ?
If you have experience with this spring please let me know, thanks.
Old Aug 18, 2006 | 11:19 PM
norapat01's Avatar
norapat01
damn....no one have any info?
Old Aug 18, 2006 | 11:43 PM
synth19's Avatar
synth19
You will need an alignment after installing the springs. You should be able to get it done within spec since the TEIN's don't lower the car that much. I would recommend going to a place that specializes in alignments. Also, NO issues with VDC. WIll the dealer still do alignments for you? YES, but not for free since you modified the suspension.
Old Aug 18, 2006 | 11:49 PM
synth19's Avatar
synth19
some specs:
Tein H.Tech Springs
Height Specifications
350Z: (Front: -0.3 in; Rear: -0.2 in)
G35 Coupe: (Front: -0.6 in; Rear: -0.3 in)
G35 Sedan: (Front: -1.4 in; Rear: -0.7 in)
Spring rates:
350Z: (Front: 358 lbs/in; Rear: 375 lbs/in)
G35 Coupe: (Front: 325 lbs/in; Rear: 263 lbs/in)
G35 Sedan: (Front: 325 lbs/in; Rear: 263 lbs/in)
One Year Limited Warranty
Free of factory defects in material, sag for free height spring length more than 5mm.
High Quality Produced by TEIN
As a manufacturer specialized in suspensions, TEIN does not allow room for any compromise. Our products have achieved both low - down form and sport specification, and are loaded with technology from the sports field of N1 endurance Racing and WRC Racing.
Cant find the s-tech specs, but if I remember correctly, they lower .06 and .07...... as long as you dont go lower then .09, you can still align the car within spec without any camber correction kits, etc. ALSO, consider doing your shocks at the same time... the OEM ones will wear out sooner. I recommend the D-Specs....
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
