nismo s tune and hotchkis sways
I'm not positive, but I believe the Nismo suspension only transfers a little roll stiffness to the rear. Therefore, you'd probably be safe setting the Hotchkis sways to medium front and back as a good starting point.
I have the RSR Ti2000 springs which have almost the same spring rates as stock up front, while being somewhat stiffer in the back. (Nothing extreme.) I originally had my Hotchkis swaybars set F:medium/R:soft, but that still had a little understeer at the limit. I have recently set my Hotchkis to medium front and back, and that seems to have helped quite a bit. Car seems a bit more neutral now. This is on public roads, mind you, so I haven't completely flogged the thing around a track with either configuration. (I tend not to push to the limit too much on public roads.) But so far I'm liking the medium/medium config.
Originally Posted by RedBird
The front has 4 settings, did you mean 48% front or 82% front, I can understand the rear which has only 3 settings, which would make it 125% for the rear.
It's the same bar as the new one, but the new one has that 4th hole added to it. Unfortunatley I'm not sure which 3 holes on the new bar corespond to the 3 holes on the old bar.
On my 3-hole front swaybar, I went with the middle.
