camber kits
Old Oct 16, 2006 | 07:04 AM
Boosting350Z's Avatar
Boosting350Z
Default camber kits
hello I have a few quick questions.. i noticed a post saying if your car is really low the CUSCO upper A arm is not what you want to adjust camber.. i noticed the SPL piece seems to have more adjustment are there any other companies that you can recomend for camber adjustment front and read any coments are apperciated thanx
Old Oct 16, 2006 | 12:18 PM
sfarrah's Avatar
sfarrah
I am not aware of any front camber arms with more adjustment range than the SPL's. You get caster adjustment also as an added bonus.
Old Oct 16, 2006 | 12:46 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Old Oct 16, 2006 | 01:28 PM
IAPDirect.com's Avatar
IAPDirect.com
SPC will offer both camber and caster adjustment. This company has been around for over 30 years and have developed kits for auto makers such as Dodge, Ford, etc. They are also the OEM of the Eibach kits.
Old Oct 16, 2006 | 03:02 PM
aleok's Avatar
aleok
the SPC offers .5 more positive camber adjustment, i thought. either way get SPL or SPC. probably best quality for great prices.
Old Oct 16, 2006 | 03:06 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Depends on the setup you have (height/wheel/tire)
Old Oct 16, 2006 | 10:09 PM
JisNis's Avatar
JisNis
So which one has more adjustment, the SPLs or SPCs?
Old Oct 17, 2006 | 12:07 PM
IAPDirect.com
The SPC kit will correct .5 degrees more camber than the SPL kit. The SPL kit can give you .5 degrees more negative camber than the SPC kit. They both offer -1 to +1 degrees of caster adjustment. SPC kit is $120 lower in cost than the SPL kit.
Old Oct 17, 2006 | 12:16 PM
taurran's Avatar
taurran
Got a link to the SPC front a-arms on your site?
Old Oct 17, 2006 | 12:32 PM
IAPDirect.com
Here you go: http://iapdirect.com/item.asp?invid=1853
Old Oct 17, 2006 | 12:48 PM
sfarrah's Avatar
sfarrah
SPC
-1.5/+3.5 camber
+/- 1 caster
Steel tubing
Rubber bushings
slip box design with set caster increments and hub spacers
SPL
-2/+3 camber
+/-1 caster
Chromoly tubing
Chromoly spherical bearings
Treaded adjusters with infinite caster adjustment within the range-nothing needs to be removed for caster/camber adjustment once installed.
Well worth the extra few bucks if you asked me.
Old Oct 17, 2006 | 12:55 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
SPC
-1.5/+3.5 camber
+/- 1 caster
Steel tubing
Rubber bushings
SPL
-2/+3 camber
+/-1 caster
Chromoly tubing
Great quick reference to show the comparison which is why I chose to go with the SPL upper arms.
http://splparts.com/
Old Oct 17, 2006 | 01:20 PM
MoodDude's Avatar
MoodDude
I can get -3 to +3 on my Kinetx A-Arms, yet a real pain in the *** to adjust. I changed there locking nut from a full to a half nut and got the extra negative camber than they advertise. And as this nut doesn't take any load from the car, there is no risk to failing. And these come with Urethane bushings.
These A-Arms are just a pain in the *** to change the camber and there is no Caster adjustment like the SPL's. Still think the 350EVO is the best design, yet you can't get them anymore.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
