HELP!Suspension Problems
Yes. But you may have simply purchased shocks that are valved no differently then the oem sedan units your removing. Their value depends on your sedan oem suspension (sport or non sport) and what oem wheel size the donating coupe had.
If you have the sedan non sport suspenison, ANY combination of G coupe oem shock will be better.
If you have a sedan sport suspension, the shocks out of any coupe that does NOT have oem 19" wheels will be the same valving wise. Meaning that if the coupe had oem 19" wheels, then those shocks would be a upgrade. However, even they won't hang the moon, their are better choices in springs that you could make. 350Z S-techs come to mind.
