Front BBK going into turns
Old Nov 8, 2006 | 05:48 PM
Drift_corners's Avatar
Drift_corners
Default Front BBK going into turns
I was going to get a wilwood 6 piston front kit 14inch for the z and then just put good pads on the rear. Im concerned about brake bias. If i come into a turn too fast, and im braking into the turn, am i going to have a disaster on my hands. thanks DO you think i need a rear kit, i have searched but alot of the time the question was asked but a good answer was not reached. people drag it off topic.
Old Nov 8, 2006 | 05:54 PM
Chebosto's Avatar
Chebosto
well, you're supposed to do most of your stopping /braking in a straight line as much as possible.. slow in, fast out... if you brake too much while turning, you might unsettle the car, and the braking would be the least of your worries..
the majority of the braking will be the front, since the majority of the weight is transfered to the front... most kits on the market (i.e. Stoptech) keep the brake bias in mind when designing the kit... i dont you really need to worry about having a rear kit or not.
Old Nov 8, 2006 | 05:59 PM
Drift_corners
i dont you really need to worry about having a rear kit or not.[/QUOTE]
it all makes sense, i dont get what you meant here, ur saying ill be fine without a rear kit. I know i want to brake b4 the turn but sometimes mistakes are made on the track and u need to ride the brakes longer than you would hope.
Old Nov 8, 2006 | 09:18 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
when you start getting into trail braking... i know my 12.9" rear stop tech kit gave me some more control... there was less dive while braking so the rear end didnt kick as easly... but it may have been the tires... :-/
Old Nov 8, 2006 | 09:20 PM
Drift_corners
so whats the verdict. can i run just the front.
Old Nov 8, 2006 | 09:48 PM
Amiricanmade's Avatar
Amiricanmade
Good thread. I have always wondered...for me, I am getting it for safety/looks. I don't really track the car so I don't really care if it matters on the track; I simply want bigger brakes to make me feel "safe" on the street.
Old Nov 8, 2006 | 11:57 PM
Alpha's Avatar
Alpha
Big brake kits won't do anything for you on the street.
Old Nov 9, 2006 | 07:59 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
In our testing for development of brake kits, we do something called a J turn test. We turn the car into a constant radius turn, and then slam on the brakes. When the car comes to a rest, we measure the distances the front and rear axle deviate from the line. If the front distance is longer than the rear, then the car is front biased. If the rear deviated further than the front, then the car is rear biased.
Not all companies make correctly biased brakes. We do it through platform specific piston sizing. Other companies take whatever caliper laying around that is closest, make a bracket and hat, and call it a big brake kit.
If a kit is designed properly, you can just get the front. If it isn't, which many times it is, you have to get front and rear. At which point, you might be dealing with other issues, like longer pedal travel.
Old Nov 9, 2006 | 08:44 AM
Drift_corners
Its true they will only stop you about 8 feet shorter than a set of stock brakes, however on the street i get my stocks to fade so its not compleatly true. Id say if you are stopin from over 120-130 you will notice shorter stopping. IMO
Old Nov 9, 2006 | 08:46 AM
Drift_corners
Ok so in the case of the 14 inch 6 piston wilwoods can i run the fronts. im willing to replace rear pads more offten seing as they are only like 45-60 bucks
Old Nov 9, 2006 | 09:06 AM
skidmarq's Avatar
skidmarq
Wow, I've been to multiple HPDE track days on the OEM brakes and pads and never got them to fade...what in the heck are you doing on the streets?
Old Nov 9, 2006 | 10:09 AM
Amiricanmade
do you have the brembo's?
Amiricanmade
8 feet shorter than the Brembo brakes or the o.e.m crappy ones?
Old Nov 9, 2006 | 10:13 AM
skidmarq's Avatar
skidmarq
No, I have a base model 350Z (non-brembo)
Old Nov 9, 2006 | 12:13 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Well said.
Chris
Old Nov 9, 2006 | 12:16 PM
Drift_corners
better to ask.... what are you not doing at the hpde events? Not intended to be mean. ur simpily not driving hard or fast enough. I drive hard i used to race carts, i brake late and hard. I find it impossible that you dont fade, or even warp your stock brakes, I do two or three 110-75, and then 1 130-60 and my stocks are rendered ineffective. I usualy pick a brake point after a few laps to get used to it, then i stick to it, i hit my point and i am 100 percent on the brakes then i ease back on the gas, you probably use your brakes conservitivly thats all.
Old Nov 9, 2006 | 12:17 PM
Amiricanmade
Me 2. I think we should just get the front and not listen to these people that won't give us the answer we are looking for. j.k
Drift_corners
there is a brake test i read where compared to the crap stock the stoptechs only stopped like 11 feet shorted. However after a few stops from 80 the stocks were at like 800 degrees and after 100 mph stops the stoptech stabilized at like 475.
Old Nov 9, 2006 | 12:20 PM
Drift_corners
yeah no kidding this goes to show you everyone who says search sucks, i search and i find something like this, not one person has had any answer to wheather or not a front kit only will work fine, a yes or a no. or something solid to go by
Old Nov 9, 2006 | 01:22 PM
skidmarq's Avatar
skidmarq
I found that it is partly my braking technique, but more likely the fact I was also running on the stock Potenzas. The tires, and not the brakes, were my weak point in my setup...they gave up long before the brakes ever showed any signs of fading...
