Adjustable Camber parts question.
Old Dec 6, 2006 | 03:15 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
on the Basic they say you can get to stock height up front, and out back their highest setting is -.1 (so essentially stock) - I've honestly never verified this, as no one really installs coilovers just to leave the car at stock height; not to mention, every car is a bit different, so not every car will exhibit exactly the same drop
Old Dec 6, 2006 | 06:34 AM
Gsedan35's Avatar
Gsedan35
I would not want 2.4" worth of spring preload (basically full preload) in order to get the front to oem ride height. Your better off at the very least to follow Tein's setup recommendation of -1"/-0.8" .
Old Dec 7, 2006 | 07:17 PM
Everybodywildou's Avatar
Everybodywildou
I basically measure that distance from the top of the coilover to the top of the spring? Is that what those sizes mean?
Old Dec 22, 2006 | 08:05 AM
Everybodywildou
ttt with my question
Old Jan 27, 2007 | 03:18 PM
nosurf2day's Avatar
nosurf2day
Originally Posted by MoodDude
With coilovers you have just opened up a new can of worms. Not only do you need to get the ride height to what you want, but you need to corner weight them! Otherwise you risk the handling to be worse than stock. To quote GRM Magazine - "If you don't corner weight your coilovers, you might as well leave the stock suspension alone."
What the heck is cornerweighting? Man I know that is a stupid question.
Old Jan 27, 2007 | 03:31 PM
Z1 Performance
Former Sponsor
it is, in a nutshell, the process by which you adjust the coilovers so that each tire is supporting as close to the same weight as possible. This is done with scales, generally by adjusting both rideheight, and spring preload. Having each tire supporting the same weight leads to a more neutral handling car that acts more predicably.
That being said, if you are not doing hardcore auto-x or track use, I would not bother investing the $$ into cornerweighting, unless you want to ring the absolutely maximum level of performance from the car on the street.
Adam
Old Jan 28, 2007 | 12:16 AM
Everybodywildou
any idea how to measure the drop on the tein coilovers? I'm basically wondering how to lower the car as much as possible and still be able to get the car back into spec.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
_bit
Oct 2, 2015 07:49 AM
