A good place for AFFORDABLE big brake upgrades!!
This site http://www.precisionbrakescompany.com/custom.html has been making big brake kits for a while for just about every car from brembo, Wilwood, and DBA components and can make any of the kits listed for the 350Z as well. Their stuff WORKS
when I talked to them they already had a Skyline kit that should be easy enough to transplant to the Z. as far as "specs" all components listed stay the same, the only part that changes ar ethe caliper brackets that are designed for each car, much the way stoptech/brembo use the same components from car to car and just use a correct bracket for each car.
I knew someone was going to say something like this
My meaning was that there is no need to give them specs from another manufacturer since the actual components dont change(caliper/rotor) just the brackets are made different for each car. As for pistons Wilwoods are also available with MANY different piston sizes as well that they can choose from dependent on each application.
Look, Im not connected to these people, If you like Stoptech, great, I think they are great too. Im just trying to pass along a place for those that want a brake upgrade without shelling out 2 grand, and the one they list as "combo B" would definitly be an improvment for a non track Z.
My meaning was that there is no need to give them specs from another manufacturer since the actual components dont change(caliper/rotor) just the brackets are made different for each car. As for pistons Wilwoods are also available with MANY different piston sizes as well that they can choose from dependent on each application. Look, Im not connected to these people, If you like Stoptech, great, I think they are great too. Im just trying to pass along a place for those that want a brake upgrade without shelling out 2 grand, and the one they list as "combo B" would definitly be an improvment for a non track Z.
xirtam
Oct 3, 2015 02:06 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
350Shadow
Sep 22, 2015 08:30 AM
