rear camber
Old Dec 18, 2006 | 04:55 PM
Chad68's Avatar
Chad68
Default rear camber
If somebody was to run a 305/30/19 on the rears, how many degree/degree's of camber if any, should be dialed out?
Old Jan 11, 2007 | 01:23 PM
m3ster's Avatar
m3ster
Bump. What about for 275/40/18 in the rear?
Old Jan 12, 2007 | 08:57 AM
Q45tech's Avatar
Q45tech
Street Tires are designed [optimized] to operate at -0.5 degrees camber, however the inablity of the suspension to avoid body roll [to make the ride tolerable] forces oem to misalign camber more negative...........as the less loaded body side rolls up [higher] reducing the static camber.
If the rear rolls +- 3" you would split the difference 1.5" = [-1.3] + [-0.5] = -1.8 degrees negative.
All depends on the amount of body roll you have at the G force you want to compensate.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
