Pics of S Techs and H Techs?
Old Jan 7, 2007 | 07:44 PM
Steve-O Z33's Avatar
Steve-O Z33
Default Pics of S Techs and H Techs?
I am thinking about lowering my car. I searched a few times and couldn't find good pics of SETTLED 350Zs with S Techs and H Techs. I want to see both for comparison. I'm looking to eliminate wheel gap without making the car sit too low for driving conveniently. If you guys can, please post up some pics of both types of springs from different angles. Thanks in advance!
Also, I know a lot of people have mixed feelings on running stock struts with these. Let me know what your setup is and how it is. I'd like to get out cheaper and use the stock struts, but not if I'm going to have to replace them after a week.
Old Jan 7, 2007 | 07:54 PM
reptile718's Avatar
reptile718
I will send you some PICS of my Z with a set of H-TECH's 2morrow when I get into work, they are stored in my office PC.
Old Jan 7, 2007 | 08:00 PM
Steve-O Z33
Nice. Thanks! I found a pic of the S Techs on the Tein website. Doesn't look too low. I have 19s, so I may sit a tad higher.
Old Jan 7, 2007 | 08:06 PM
reptile718's Avatar
reptile718
I am also running 19's with a Veilside V1 lip kit, It is just high enough to clear most speed bumps and get me through some bad NC roads. Anything lower I would not really recommend, I find it hard sometimes to clear some places with slopes or inclines w/o scrapping a little bit. Also take into consideration after the install it will sag more over time. My Z sits very close to what is pictured above.
Old Jan 7, 2007 | 08:08 PM
Steve-O Z33
Yeah, that's why I'm thinking H Tech. They advertise that you can use the stock struts and they'll sag some. I had eibachs on my old car and they sag REALLY bad. The 1.3" drop ended up being like 2"+.
Old Jan 7, 2007 | 08:14 PM
reptile718's Avatar
reptile718
I combined mine with the revised 2006 struts and shocks and it was like night and day. Ride quality improved greatly. Still I felt that it was not quite stiff enough. I recently sold the suspension and will be pairing up the H-TECH's with NISMO S-Tune shocks and struts. I think this will make a perfect combination of performance and comfort.
Old Jan 7, 2007 | 10:04 PM
Mike Wazowski's Avatar
Mike Wazowski
here is mine on S Techs and Tokicos.
18" Nismo LMGT-4 wheels with 245/40 F and 275/40 R
Old Jan 8, 2007 | 05:18 AM
z-u-later's Avatar
z-u-later
Here are a couple of pictures of my Z with Tein S on stock rims/tires. I have spacers just so you know (20mm in front & 25mm in rear).
Old Jan 8, 2007 | 07:25 AM
reptile718's Avatar
reptile718
As promised here are some pics with the H-TECH's.
Front:
Rear:
Side (before the Stillen S/C):
Old Jan 8, 2007 | 09:29 AM
Steve-O Z33
Hmmmm... still hard to decide. Not much difference. I'll probably get S Techs. I'm thinking since they have higher spring rates, they won't sag as much over time.
Old Jan 8, 2007 | 09:33 AM
z-u-later's Avatar
z-u-later
BTW, with the Tein S, I'm still using my stock shocks. It's a mild drop with the Tein S -- about 3/4" all the way around. It's dropped but not too low that you're scraping all the time. I've driven my Z to HPDE & autocross with no issues on the suspension.
Old Jan 8, 2007 | 10:06 AM
BaTMan_4's Avatar
BaTMan_4
^ i always thought that running spacers and racing would be kind of dangerous since the tire isnt directly connected to the car's axle...not shure if thats what you would call it. How many miles have u been on spacers, and do u have any rear shots of your car??
Old Jan 8, 2007 | 11:11 AM
Steve-O Z33
imo, spacers are fine as long as you keep a check on your lugs. After installing spacers, you need to retorque them after about 50 miles. They'll need it.
I've pretty much decided on the S Techs. 3/4" on stock shocks/struts is about what I need. Thanks for all the help!
Old Jan 8, 2007 | 11:54 AM
z-u-later's Avatar
z-u-later
The rims/tires are most certainly attached to the axles the same way as any other rims/tires without spacers. They're still bolted on. The kit came with longer bolts to accomodate the spacers. There are many members here who use spacers and take their Zs to the track and never have any issues with spacers. I've taken mine to the track & auto-x and have no issues either.
Old Jan 8, 2007 | 12:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
H-tech = don't bother.
virtually no drop
Old Apr 13, 2007 | 07:40 PM
black06z's Avatar
black06z
wow!! the s.tech's give a pretty decent drop. maybe I should keep mine.
Old Apr 22, 2007 | 08:08 AM
Kimosabe's Avatar
Kimosabe
is the s-tech drop more noticable in person??
Old Apr 22, 2007 | 09:26 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I think you need to see the side by side to get a good idea about the drop. The top picture is stock springs, the lower on S-tech springs.
Chris
Old Apr 22, 2007 | 09:29 PM
black06z's Avatar
black06z
^^what year is your Z?
Old Apr 22, 2007 | 09:58 PM
HyperSprite
Mad Scientist
04.5
