Finally... Pics Hotchkis TVS Kit
Old Jan 8, 2007 | 08:33 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Talking Finally... Pics Hotchkis TVS Kit
Did a quick wash of the car this morning. These aren't the best pics but here they are:
Old Jan 8, 2007 | 08:44 AM
Diesel350's Avatar
Diesel350
Looks good. Nice drop. How do you like the sway bars?
Old Jan 8, 2007 | 08:46 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Lovin' the kit!!! Sways are awesome! Really haven't tested them out with all this Colorado snow. However the car does feel great!!!
Old Jan 8, 2007 | 04:16 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Man.... All these people asking for pics and no responses.
Old Jan 8, 2007 | 04:18 PM
rotaryrocket7's Avatar
rotaryrocket7
looks good. Keep the thread active and when you get a chance to really push let us know if you have any understeer left.
Old Jan 8, 2007 | 04:32 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks! I'll try to keep it active but it depends on how many people make comments as well.
Old Jan 8, 2007 | 04:37 PM
glowz825's Avatar
glowz825
That the set up i am going to buy....Looks sweet!!!!!
Old Jan 8, 2007 | 04:39 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks! Its a great kit!!! I got mine through Intense for $399 shipped. To bad you missed out on the $50 rebate through Hotchkis.
Old Jan 8, 2007 | 05:09 PM
MyZFiona's Avatar
MyZFiona
did u keep your stock shocks and struts with the TVS kit...? cause i'm doing the same drop kit but i'm replacing my stock shocks and struts.. just wanted to know if the ride was still the same or worse or better with the stock struts.... some feedback would be awesome
Old Jan 8, 2007 | 05:12 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Ride feels great. Running stock struts. Plan to upgrade to Koni in the future.
Old Jan 8, 2007 | 05:19 PM
hiz-n-herz's Avatar
hiz-n-herz
Looks good. This is the kit I'll go with eventually. The back looks super-low. You got a stereo system back there?
Waiting for the subjective review...
Old Jan 8, 2007 | 05:23 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
No audio system.
Old Jan 8, 2007 | 05:42 PM
Firemedic's Avatar
Firemedic
Nice choice, I have the same... running tokico dpecs with them also. Just wait till the weather cooperates, then the real fun will begin.
Old Jan 8, 2007 | 05:46 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Sweet! How do you like this kit w/ the tokico dpecs? Considering those as well.
Old Jan 8, 2007 | 05:50 PM
hr2burn's Avatar
hr2burn
Is that lower? How much lower. I plan on doing coil overs, as far as sways this seems to be the way of choice.
J-man
Old Jan 8, 2007 | 06:08 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Yes its lowered.
Front Front 9/16" (15mm) Drop
340 lbs/in
Stock 310lbs/in
Rear 3/4" (19mm) Drop
330 lbs/in
Stock 350 lbs/in
Old Jan 9, 2007 | 05:16 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Here are the sways bar specs:
Specs:
Front: 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear: 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
Front:
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
Old Jan 9, 2007 | 11:14 PM
350z_drifter's Avatar
350z_drifter
nice can't wait to hear how it handle in the dry pavement
Old Jan 9, 2007 | 11:30 PM
Mazinger Z's Avatar
Mazinger Z
I have the same set on order. Just a quick question. I have Tokico's Dspecs as well...I'm planning to do the install myself. What would I need? I have a socket set, jack, and jackstands. Would I need a spring compressor?
Old Jan 10, 2007 | 04:31 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
How do you like the Tokico's Dspecs? Thinking of getting a set as well. Install is pretty easy but I don't like dealing with springs so I had someone install mine. You will need spring compressors. Suggest a torque wrench as well as the nuts/bolts are torque pretty good.
