Squeaking...new rotors with brakes?
Old Jan 15, 2008 | 03:24 PM
  #41
StopTech's Avatar
StopTech
Vendor - Former Vendor
We used to offer this but now that most kits are stocked and ready for immediate shipment, it is not feasable to tear everything open to change the pads out.
Old Jan 17, 2008 | 07:44 AM
  #42
VO...'s Avatar
VO...
Administrator
Clipdin wanted to know if my how my PosiQuiets are still doing. I am happy to report I took the Z out last night for a 15 minute drive. Outside temp was 57 degrees. The brakes are still quiet. I believe I heard one tiny squeak during the entire trip.
Old Jan 17, 2008 | 10:47 AM
  #43
Clipdin's Avatar
Clipdin
SHIFT_happens
Great news VO!!! Hey, I took your advice and called brakewarehouse.com and ordered a set for me too! Talked to a guy named Chuck (nice guy) who helped me order them. I ordered the whole set for fronts AND backs. Get this, the specs recommend the Posi Quiet ceramics for the front 4-piston calipers and the semi-metallic (which is what you got) for the rear 2-pistons.
Gonna try to install them this weekend. Not sure if I will install the fronts if the current pads don't squeal....yet????
Thanks again for laying the groundwork and doing all the testing on your brakes man! I'll be glad to buy you a beer or three!
Old Jan 17, 2008 | 02:22 PM
  #44
StopTech's Avatar
StopTech
When I had the stock Brembos on my STi, I used the 104 pads front and rear and was very happy with them. They felt almost as good as stock in terms of bite (the stock Brembo pads are quite good) with almost no dust and no noise whatsoever. I recommend them to people all the time who want a nice inexpensive low noise and dust pad.
Old Jan 17, 2008 | 02:50 PM
  #45
VO...'s Avatar
VO...
Administrator
Sweet man! Chuck is who sold me my pads too. The front axxis UTL's should be fine. My fronts have never had any problems, even in the cold, but's that's because fronts always bite harder than rears. That is where most braking power comes from. You could try leaving the axxis UTL's on the front and just swap the rears. You'll have better bite with the axxis fronts than the PosiQuiet ceramics.
Glad I could help someone not have to go through the same thing I did...
Old Jan 18, 2008 | 08:14 AM
  #46
VO...'s Avatar
VO...
Administrator
Default One last update..
Outside temperature dropped to 50 degrees last night. I took the car for a spin. The rear pads are still quiet.
Old Jan 18, 2008 | 05:43 PM
  #47
Clipdin's Avatar
Clipdin
SHIFT_happens
Hey VO, got my pads today, gonna put them on tomorrow. You answered my question. I was wonderin about just changing out the rears and leaving the Axxis up front. Didn't wanna change em out if I didn't have to.
Hey, these things say they are scorched and need no break in?? Did you bed these pads when you put em on? Or can I just slap em on and be done? Then again, not sure if you can try to bed your brake pads if you only swap out the rears????
Old Jan 19, 2008 | 01:02 AM
  #48
VO...'s Avatar
VO...
Administrator
If you are only swaping the rears, just replace them. dont worry about any bedding, they dont need it.
So yeah, just slap them in and be done with it.....
Old Jan 19, 2008 | 08:38 AM
  #49
Clipdin's Avatar
Clipdin
SHIFT_happens
Default Ahhhhhhhhhh, music to my ears!!!!
NOTHING!!! Just swapped out my rear pads for the Posi Quiet semi-metallics. NO MOAR SQEALING!!!!! THANK YOU VO!!!!!!
Old Jan 19, 2008 | 12:46 PM
  #50
reserved's Avatar
reserved
That is great news! I'm gonna do the same! I've put up with this for 6 months now, hoping it would get better (- which of course it didn't).
Old Jan 21, 2008 | 06:21 AM
  #51
VO...'s Avatar
VO...
Administrator
Werd! Glad I could help you out man.
Old Jan 24, 2008 | 02:36 PM
  #52
HaNkYs_Z's Avatar
HaNkYs_Z
Subscribing, thanks!
Old Jan 25, 2008 | 12:50 PM
  #53
VO...'s Avatar
VO...
Administrator
Old Jan 25, 2008 | 12:51 PM
  #54
VO...'s Avatar
VO...
Administrator
How the brakes? Still sounding good? Mine are. I took the Z out for a late night stroll @ outside temp 42 degrees. Still runs quiet....
Old Jan 25, 2008 | 02:49 PM
  #55
Clipdin's Avatar
Clipdin
SHIFT_happens
I've heard nothing until today when I heard the slightest of squeeks for less than a second. Soooooo happy!! And since I just swapped out the rears, the fronts are still nice and strong.
Old Jan 28, 2008 | 07:39 AM
  #56
VO...'s Avatar
VO...
Administrator
Cool that's good to hear....
Old Jan 28, 2008 | 06:37 PM
  #57
oviedov23's Avatar
oviedov23
I bought my Z about a month and a half ago and my rear brakes squeal pretty loudly but only when I first start driving like after it stands for a night or so, is that normal in a Z or should I get it checked.
Old Jan 29, 2008 | 04:03 AM
  #58
reserved's Avatar
reserved
I have done the same thing (replaced rears only). Took care of the squealing.
Thanks guys
Old Jan 29, 2008 | 05:32 AM
  #59
Clipdin's Avatar
Clipdin
SHIFT_happens
Thanks guys
Another happy customer.
Old Jan 29, 2008 | 06:39 AM
  #60
deanfootlong's Avatar
deanfootlong
my brakes squeal a lot too. its almost time for me to replace the brake pads. i have brembos so do i have to replace my brembo rotors or can to get them turned/cut/resurfaced? usually when i change brakes on a vehicle i always get the rotors turned but now that i have a car with brembos.... whats the general consensus?
PS: my brakes squeal a ton when they get really warmed up after a highspeed brake. thoughts?
