HELP! Sway bar install
Old Feb 27, 2007 | 08:20 PM
txgoalie's Avatar
txgoalie
Exclamation HELP! Sway bar install
How in gods name did you get the stock bolts off of the front sway? I cant seem to do it...
it is impossible, I have a bolt extender, but it still seems like there is no room to get it done.
do did you do it?
I have an '06 if that makes a difference
Old Feb 27, 2007 | 08:30 PM
creationv2's Avatar
creationv2
if you search...youll find people advising using penetrating spray to loosen up the bolts...they never mentioned a brand or anything..but i dont mind asking that at the local hardware store or autozone or something...
Old Feb 27, 2007 | 08:32 PM
txgoalie's Avatar
txgoalie
ive searched. I don't have any penetrating spray, and no open auto stores. kinda need an idea that uses what i have now.
Old Feb 27, 2007 | 08:37 PM
Chebosto's Avatar
Chebosto
WD40? &/or "breaker bar"
are you hand wrenchin' it? or do you have impact tools?
Old Feb 27, 2007 | 08:39 PM
txgoalie's Avatar
txgoalie
sadly, im doing it by hand. my regular ratchet is too small, and my torque qrench is too big.. i may have some wd-40 tho, I'm gonna try to find it.
Old Feb 27, 2007 | 09:03 PM
txgoalie's Avatar
txgoalie
sometimes it just doesnt matter how hard you try, you just aint gonna get it.
Old Feb 27, 2007 | 09:10 PM
LaoSiFu's Avatar
LaoSiFu
It isn't easy because those nuts are on there tight.
Old Feb 27, 2007 | 09:45 PM
fresnel151's Avatar
fresnel151
Try to find some PB Blaster penetrant. Pep Boys usually has it. Don't know what the temperature is in your work area, but cold, tight bolts are a bear to break loose. A warmer work area could help along with a good dose of PB Blaster. The torque wrench shouldn't be used to break bolts loose.
Old Feb 27, 2007 | 10:33 PM
txgoalie's Avatar
txgoalie
Tell that to my knuckles haha..
Well I gave it my best shot, and managed to break only one bolt. I'll be taking it to a shop this weekend =\ . It'll be the first time ive ever had to have a shop install something for me..very sad..
Anyway, anyone know how much a front/back sway install should be? and a good shop to do it in the SF bay area?
Thanks
Old Feb 27, 2007 | 10:35 PM
LaoSiFu's Avatar
LaoSiFu
Thanks
I know down here @ Corner 3 Garage, I paid roughly (if I remember) about $75.
Old Feb 27, 2007 | 10:49 PM
Mazinger Z's Avatar
Mazinger Z
I used handtools also. Jack up the car higher so you have more clearance. Remember to use jackstands too. Try using a breaker bar if you don't have impact tools. What I used was my socket wrench + the handle off my jack to make my own breaker bar. It worked and I got it off but took some effort.
Old Feb 27, 2007 | 11:02 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
you dont have a 24 hour walmart??? go buy some pb blaster, put some heat on the bolts. do you have a heat gun or a micro torch.
Old Feb 27, 2007 | 11:41 PM
creationv2's Avatar
creationv2
^^or if youre desperate a blow dryer haha
have you tied using a rubber mallet and the wrench? idk if youre nto supposed to do that....but it hasnt hurt me yet on the random things i cant do by hand
Old Feb 28, 2007 | 02:39 AM
devildoc's Avatar
devildoc
A breaker bar is a must. I'm not sure how much clearance you have, but I was on some jackstands and was able to use a 15'' breaker and a 6'' extension. They all came right out! Trying to do it with a regular wrench was impossible.
Old Feb 28, 2007 | 03:27 AM
Eazzy's Avatar
Eazzy
Nothings Impossible. As stated, keep ur socket extention as short as possible because transmited energy is lost the longer it is, and use a breaker bar with an extention thats 4 ft if u have to.
If a bolt is just plain tite and virgin ( as in an 06 ) or even an 03, all the penatrating oil in the world is not going to help. Penatrating oil isnt magic and cant penatrate what it cant get to. Ur wasting ur time and the oil. All u need is muscle, whether it be ur own, or artificially increased via a breaker bar, or ideally an air Impact.
So I dont get ranted on ---Penatrating oil is great, I use Liquid Wrench. I have soaked rust seized pistons, previously removed bolts and pins that are seized, along with heat ( Butane torch, and I RELIZE penatrting oil is flammable ) rims that are seized on the hubs, U-joints that are stuborn etc etc. But they are in all instances, situations where at one time that part has been assembled/reassembled.
Good Luck !!!! AND those bolts dont have to go back that tite---Assembly line bolts are just plain too tite usually---Use Anti-Seize on reassembly. I even use it on U-Joint cups, the next guy will thank u.
Old Feb 28, 2007 | 07:04 AM
txgoalie's Avatar
txgoalie
Walmarts are few and far between in Norcal. I wish I was back home in texas. I also don't have a breaker bar. My torque wrench has been doing that job.
Old Feb 28, 2007 | 07:08 AM
txgoalie's Avatar
txgoalie
This has all been great advice. I will definitely equip my garage with a few more tools after reading this thread.
But, for now, my hands are too beat/cut up to want to go tackle that thing again, so I think I'll just take it to a shop anyway. I just hate the thought that I couldn't do it myself.
Thanks again, Everyone
T
Old Feb 28, 2007 | 07:11 AM
MikeEwithTheZ's Avatar
MikeEwithTheZ
just put your wrench on and get a longer metal pipe and put it over the handle...ghetto tools work every time
Old Feb 28, 2007 | 09:30 AM
Eazzy's Avatar
Eazzy
And dont EVER use ur torque wrench again as a breaker bar !!!! For Shame !!!!
Hit Sears ASAP and get one of their tool SETS
Old Feb 28, 2007 | 09:39 AM
txgoalie's Avatar
txgoalie
Yah I know I know. It was a cheap torque wrench, and it gets replaced for free if it breaks. Thats the reason why I use it. When I did my spring install on my tc, I actually broke a breaker bar. Thats when the torque wrench stepped up and took its place.
