Help with suspension issues....
Old Mar 5, 2007 | 05:15 PM
jmr0311's Avatar
jmr0311
Default Help with suspension issues....
At what problem can you guys attribute a lot of vibration inside the cabin of the Z at high speed. The vibration is to a level that the dash panel also vibrates and makes noises on a bad way. I checked an put air on the tires and also got the car aligned but the improvement was very minimum. The rear suspension still very sloppy . I just want some advice on what might be the reason for this deterioration in handling on my Z. This are the number the alignment shop was able to get on my Z,
Front Camber: -1.2 degrees (Left) and -1.2 degrees (Right)
Front Toe: .08 degrees (Left) and .06 degrees (Right)
Rear Camber: -1.9 degrees (Left) and -2.0 degrees (Right)
Rear Toe: .11 degrees (Left) and .11 degrees (Ri
Old Mar 6, 2007 | 06:59 AM
Q45tech's Avatar
Q45tech
Have each tire/wheel radial force balanced on a GSP9700 machine you will be surprised at how inferior the typical balancers are.
http://www.gsp9700.com/pub/technical/4127T/4127t.cfm
Old Mar 6, 2007 | 07:01 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
+1, the shop I take my wheels to, use this. My car tracks well, and I have gained more mileage per set.
JCat's Avatar
JCat
Vibration could also be caused by a damaged driveshaft or driveline.
Old Mar 6, 2007 | 07:52 AM
azula's Avatar
azula
^+1
there's a lot of things that can be attributed to vibrations, not just camber
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
