is it the same?
Old Mar 26, 2007 | 08:32 AM
03TEZ's Avatar
03TEZ
Default is it the same?
is the diy that they covered on the non brembo brake pad install the same as the brembo ones. do i do the same thing or is there some other stuff that needs to be done? i searched but all i found was the diy on a non brembo. just wanted to see if i would run into anything different. thanks for any replys in advance.
Old Mar 26, 2007 | 09:43 AM
NoahzBurnt's Avatar
NoahzBurnt
u need to actually remove the caliper from the bracket with non-brembo brakes as opposed to just sliding in the brake pads.....
