Quick Q
Old Apr 5, 2007 | 03:02 AM
03trackguy's Avatar
03trackguy
Thumbs up Quick Q
have a 03 track and just installed a set of tein s should i have the camber redone ?
Old Apr 5, 2007 | 03:24 AM
Glentismichel's Avatar
Glentismichel
You should've had the shop check the camber after the install just to make sure.
Old Apr 6, 2007 | 01:19 PM
Gsedan35's Avatar
Gsedan35
A Z dropped on S-tech's should be within oem alignment specs. Since you have to break free the bolts in the rear that set rear toe, it's alway's a good idea to visit a alignment shop to have the car aligned.
Old Apr 6, 2007 | 01:27 PM
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
Hello,
In order to answer your question w/ any true empirical answer, you should wait for the springs to settle. Normal driving (~230 miles) after 1 week, and they should be settled. Take the car to an alignment shop so they can determine where your camber #'s are at. They will be able to tell determine, based upon your numbers, and what's considered by Nissan as the acceptable range of negative camber, if camber kits are recommended.
D.
Old Apr 7, 2007 | 04:55 PM
IIQuickSilverII's Avatar
IIQuickSilverII
if you daily drive it id say do it in 2-3 weeks.... get a rear adjustable camber kit from Intense though, dont take chances having it aligned and you are still off on the rear cambers
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
