mixing sway bars?
Old Apr 13, 2007 | 10:11 AM
chris'smax's Avatar
chris'smax
Default mixing sway bars?
I recently purchased a progress front sway bar and was about to purchase the rear but i am not sure if it will clear the HKS high power TI exhaust. I was looking at getting the cusco rear becasue i know it will fit. Would mixing these two be a bad idea? Both are solid bars and are adjustable.
Old Apr 13, 2007 | 02:14 PM
Scarab440's Avatar
Scarab440
the important thing to consider here is how stiff are the bars. is there a hole on the cusco rear bar the closely matches the stiffness of the Proressive rear bar?
I mixing Swaybars CT1 front hotchkis rear.. I still need to install the rear..
Old Apr 13, 2007 | 02:19 PM
chris'smax's Avatar
chris'smax
I can't find the stifness setting for the progress bar. I found the cusco though.
Old Apr 13, 2007 | 03:38 PM
DavesZ#3's Avatar
DavesZ#3
Mixing shouldn't be a problem. It seems like all aftermarket bars are adjustable and everybody uses different settings depending on the desired effect. Different brands shouldn't really matter, it's the stiffness value that ultimately matters.
Old Apr 13, 2007 | 04:04 PM
chris'smax's Avatar
chris'smax
Thanks for the replies guys. I went ahead and purchased the progress rear also. I figure if it doesn't fit i'll just sell the SOB. Hell for $140 shipped i figure it is worth the risk.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
