Uhh, oh...
Old Apr 15, 2007 | 07:04 PM
JoeyFyed's Avatar
JoeyFyed
Default Uhh, oh...
So i was changing my oil today, and went ahead and looked at my sway bars to see if everything was cool. this is what i found.
Car felt fine driving so i was never worried, now the end link seems fine i just cant find the bolt, the thing just ripped off.
I heard SPL end links are good, can anyone recommend me some good stuff so this doesnt happen again. thanks...
Old Apr 15, 2007 | 07:06 PM
I don't know what it is but put it back together again.
Old Apr 15, 2007 | 07:08 PM
Jay'Z's Avatar
Jay'Z
Uh.. Just get another bolt..
Old Apr 15, 2007 | 07:10 PM
JoeyFyed's Avatar
JoeyFyed
Lol, yea not driving the car till i get it fixed. Also don't feel like taking off the other bolt to math them, does anyone know the size so i can temp. put it on for the trip to the shop.
I definitely don't wanna just get another bolt and wipe my hands, scared of this happening again.
Old Apr 15, 2007 | 07:25 PM
roast's Avatar
roast
weld it
Old Apr 15, 2007 | 07:54 PM
Boosted4's Avatar
Boosted4
So you been driving it god-knows-how-long and you could never tell? Now you won't drive it 20 miles to get it in the shop? I think it would be fine to drive to the shop to get fixed, just dont drive it cross-country.
PS: good reason to upgrade
Old Apr 15, 2007 | 07:58 PM
black06z's Avatar
black06z
lol. you have a good point there.
Old Apr 15, 2007 | 07:59 PM
bofa's Avatar
bofa
new bolt + loctite?
Old Apr 15, 2007 | 08:08 PM
mthreat's Avatar
mthreat
1. go to nissan dealer
2. have them get the nut, using the diagram on their computer. they'll probably have it in stock. If I recall, it's either a 14mm or 17mm nut.
3. look in the service manual, FSU section (front suspension) to find the torque spec for it. Hint, page FSU-8, it's 59-70 ft-lbs of torque.
4. use loctite if you want.
5. check the other side too, and the nut on the other end of the small endlink (it's also 59-70 ft-lbs).
Old Apr 15, 2007 | 08:10 PM
HDPDZO6's Avatar
HDPDZO6
Don't think the dealer is going to be willing to reconnect aftermarket sways. Unless it's a mod friendly one.
Old Apr 15, 2007 | 08:16 PM
doskiez's Avatar
doskiez
He was just sayin go to the dealer to get the nut because he didnt know the size........
Old Apr 15, 2007 | 08:20 PM
HDPDZO6's Avatar
HDPDZO6
Gotya. You can also download the service manual and look up the nut.
Old Apr 15, 2007 | 09:08 PM
Z'd Up's Avatar
Z'd Up
luckily, you found it now.
Old Apr 15, 2007 | 09:10 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
Use some gum.
Old Apr 15, 2007 | 11:34 PM
mthreat's Avatar
mthreat
Originally Posted by HighwaySpeed
Use some gum.
Old Apr 15, 2007 | 11:37 PM
iStan's Avatar
iStan
ZR
Use some gum.
Or GAK. Sticks and gives you a new noise mod.
Old Apr 16, 2007 | 12:02 AM
JAB_06-350Z's Avatar
JAB_06-350Z
Old Apr 16, 2007 | 12:24 AM
JoeyFyed's Avatar
JoeyFyed
Thanks for the help guys, well yea i decided on going to the shop after i posted this. Gotta go sometime this week, need a new set of tires anywho, or else i mightve been able to do it myself.
So are the upgraded end links worth it?
Old Apr 16, 2007 | 04:22 AM
Kolia's Avatar
Kolia
Considering you've been driving around with NO sway bar and didn't notice it. You should ask yourself if the swaybar upgrade it self was even worth it !
Old Apr 16, 2007 | 06:35 AM
Gsedan35's Avatar
Gsedan35
Thing I don't understand is, the process of that nut working it's way loose and then falling off should have been heard and really annoying. Did you install the bars or did a shop? How are the threads on the bolts?
I know that on my Hotchkis front bar that I had a difficult time getting enough torque on that same nut/washer to keep it in place, because it would slip and pop under high load situation's. I ended up ruffing up a pair of washers and reinstalling and that kept everything in place.
I know run SPL front end links, highy recommended. Though oem end links should stil work fine for you.
