Camber Settings for rear
Old Apr 29, 2007 | 04:11 PM
VIZAGE's Avatar
VIZAGE
Question Camber Settings for rear
Well I notice the other day that on my inner rear tire that the tread is about gone. The rest looks great. This is after 10,000 miles. In which I do drive hard alot. I have no problem with this.
Just want to know what my rear camber should be set at when I go for my alignment soon? I'm also going to buy a adjustable camber kit for the rear. My last check on my alignment was as follows: Left rear -2.1 Right rear -2.0 Everything else looks good. Just want to reduce some wear. I want it set up for aggressive driving, with the best life I can get out of my tires. So where should camber be set?
Old Apr 29, 2007 | 04:18 PM
plumpzz's Avatar
plumpzz
Depends on the tire. Some tires like camber, others dont.
Old Apr 29, 2007 | 05:26 PM
redlude97's Avatar
redlude97
toe is more important than camber, so make sure your toe is set correctly. For camber, somewhere around -1.5-1.7, toe, .05-.1 for a good compromise between handling and tire wear
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
