Do i need a pos or negative camber kit
Old May 29, 2007 | 05:39 PM
b_rabbit023's Avatar
b_rabbit023
Default Do i need a pos or negative camber kit
Hi Guys !!
I just bought myself some Tein Coilovers for my 350z.
After lowering my car, i realize that my tires are like this /_/ \_\ i don't know how to explain well, i'm sorry English isn't my first language and i still have a lot to learn. they are using from the inside of the tires.
My Question is will these cusco or Megan Racing A-Arms correct my problem
http://thezstore.com/page/TZS/PROD/23-4182
https://my350z.com/forum/showthread.php?t=252251
thx a lot for your help guys !!!!
Old May 29, 2007 | 06:36 PM
Checkmate58's Avatar
Checkmate58
For the front of the car, you will need adjustable control arms such as this:
http://intensepower.com/necaupa35g35.html
For the rear of the car, you will need to correct camber and toe. You can either go with Camber arms and Toe arms:
https://my350z.com/forum/northern-california/209153-share-experiences-with-battle-version-camber-and-toe-arms-kit-pics-included-2.html
Of you can go with Camber Arms and toe bolts:
https://my350z.com/forum/brakes-and-suspension/272066-stillen-or-spc-camber-kit.html
--Sam
Old May 29, 2007 | 06:57 PM
b_rabbit023
so these Megan Racing A-Arms will correct my problem right ?
Old May 29, 2007 | 07:13 PM
Checkmate58
^^I don't know if any members have had experience with the Megan arms but if they are like the Cusco's (they look just like them), then that will correct the camber in the FRONT.
As for the REAR, that is another story and you cannot put those arms in the rear of your car.
--Sam
Old May 29, 2007 | 07:14 PM
b_rabbit023
cool !!! thx alot for your quick responses Sam i only need a front camber kit cuz my rear wheels seems ok !!
Old May 31, 2007 | 05:01 AM
1nate7's Avatar
1nate7
In that add it says Megan will only adjust more negative, which is not what you need. There is a small amount of positive adjustment (~.5 degree) with the Cusco arms. I don't have any experience with them, but the Kinetix arms are probably the cheapest way to fix your front camber issue.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
