suspension help
i am currently running 19 hiros, but a drunk driver came over on me a few weeks back and to avoid contact i hit a curb and messed the up. so now i am about to order 20 shines, plus put on stillen sways and tein springs(it will drop it .7 in the front & .6 in the rear) and i was thinking of buying battleversion camber arms, because i noticed an uneven wear in my tires with the 19's. so my question is: with the 20's and the drop and stiffer suspension with i need camber arms and will i have to cut the fenders so the don't rub?
thanks in advance
-edsel
and i am sure the repost ***** will believe this is a repost of some sort. but my question is for people that are running a similar set up as i want to.
thanks in advance
-edsel
If it's less than 1" drop, you dont need camber arms. But I would recommend them if you track the car since I bent my OEM ones just for going up the racing curb. Aftermarket especially battleversion ones are beefier after all.
As for fender roll/cut, it solely depends on width and offset of the rims as well as the height of the car. Given your drop, I doubt you'd rub.
P.S. this info can be searched up
350Z_Al
Oct 29, 2020 07:44 PM
