Alignment Readout/specs help
Old Jul 5, 2007 | 05:35 AM
Juicehead's Avatar
Juicehead
Default Alignment Readout/specs help
Hey all, can anyone help me interperet this
Before = before they adjusted
Actual = new adjusted value I assume???
Some of the "actual" values are grayed out. Does this mean they did not adjust?
thx for any help
Old Jul 5, 2007 | 09:31 PM
Gsedan35's Avatar
Gsedan35
thx for any help
Before is just that, before they made adjustments.
Actual is the end result of them making the changes they could and showing you the results afterwards. I'm not sure why they show some of the numbers in a lighter gray. Your out of spec on front camber since the max spec is
-1.33. Your right at the max rear camber spec on the right side, max spec is
-2.08 Toe settings look fine, though I'm assuming all setting are for toe in and NOT toe out.
Did you set the car up to a 1"/.8" drop? If not what drop setting did you use?
Old Jul 6, 2007 | 03:40 AM
DavesZ#3's Avatar
DavesZ#3
It looks like the "grayed" ones are the ones that are in spec. Therefore the bold ones are out of spec.
Old Jul 6, 2007 | 04:20 AM
Juicehead's Avatar
Juicehead
Yes, for the most part the standard, I went a little lower in the rear. I am about a finger width on both sides in rear...but for some reason a little higher in left rear
I guess I will be investing in camber arms soon...
emooheo
Oct 14, 2015 08:58 AM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
