Racing guys.. how much of negative camber you use?
Old Aug 5, 2007 | 01:03 PM
Ataru074's Avatar
Ataru074
Default Racing guys.. how much of negative camber you use?
I see almost everybody wants to go back in spec.. Ok my car is sligly lowered (nismo S tune + nismo sways) and I'm still having not enough negative camber in front.. my tyres are telling that bad. I got the cusco A arm and I have to install, but just because it looks a pain in the a$$ I'd like to know how far you pushed yours.. I'll try with 8mm setup (looks like should add about 1 1.2 deg per side... just stupid math.)
I'm not concerned about tire wear on inside or "tracking"... my old car was at -3.5 F and -2.4R and was DAMN fast inside the turns... so.. what you do run?
spec? -2 per side? -3?
thanks Matteo.
Old Aug 5, 2007 | 05:33 PM
Gsedan35's Avatar
Gsedan35
This may not sound like a reply that's in the spirit of help, but it is. Why would you ask the question when the setting you should be running, the setting that is the best for YOU is the one gained from testing with a tire temp guage and adjusting the camber to get the best temp spreads? You can ask for general knowledge what they are running, but until you take temps to see what is going on, you will never know if your getting the most out of the settings or not.
ps if you search the word camber and limit the search to the autocross/road racing section you'll find out those settings.
sherm
Apr 11, 2020 05:21 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
