What is you hotchkis position of the sway bar hole you are using
Old Aug 29, 2007 | 10:25 PM
350Zimo's Avatar
350Zimo
Default What is you hotchkis position of the sway bar hole you are using
I 've just got my Hotchkis sways , i've had the car for 6 months , i drove a celica before , and as you know it is FWD. So , my question is , i do expect my stiffness to increase, should i expect the car's "behavior" on the road to drastically change, i mean under-over steering .and would you recomend for a fairly new person with RWD to begin with regular stiffness or as i am thniking of making the sway bars as stiff as they can be ? I kinda want my car to be feel like an autoX, and handle great.
Old Aug 30, 2007 | 09:32 AM
Triple8Sol's Avatar
Triple8Sol
Do you have the ones with 3 holes or 4? I have the 3, and I'm running med/med f/r.
Old Aug 30, 2007 | 09:46 AM
Chest Rockwell's Avatar
Chest Rockwell
I'm running the stiffest set up f/r. Love it. Tried to change it, and it felt weird, so i changed it right back.
Old Aug 30, 2007 | 10:22 AM
Mazinger Z's Avatar
Mazinger Z
I'm using med/F and light/R. Car is very neutral, no oversteer. Great if you're throttle happy on tight turns.
Old Aug 30, 2007 | 10:42 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
best way is to play around w/it as everyone driving feel is different. Start w/ what the manufacture suggests, then make adjustments that fit your style.
Old Aug 30, 2007 | 10:45 AM
dkmesa350z's Avatar
dkmesa350z
You should do stiffest up front and one or two down from the stiffest in the rear (depending on whether you have 3 hole or 4)
Old Aug 30, 2007 | 12:43 PM
redlude97's Avatar
redlude97
there is only 3 holes in the rear for both sets, only the fronts got 4 holes
Old Aug 30, 2007 | 03:54 PM
Z1NONLY's Avatar
Z1NONLY
I used the sways to get rid of a little understeer. They worked great and the car is as close to neutral as I have ever felt.
R=Softest, F= 1 hole in from softest.
This is with 275/40-17 rear tires and 255/40-17 front tires.
How does your car feel now?
Old Aug 30, 2007 | 09:28 PM
350Zimo's Avatar
350Zimo
sorry about the delaied reply, anyways , i insatalled them today, and it was pretty simple , and i have the sway with the 4 hole front and 3 rear , i am on 245/30 19 inch front and 285/35 rear, so i was told that if i used one hole before the stiffest in the front the car would feel perfect no understeering, nothing - as i did, rear i am currently on the stiffest setting, but i am going to experiment , but the way it is now is just a beauty, handles , corners , love it.
Old Aug 30, 2007 | 11:09 PM
terrasmak's Avatar
I love that setup , but im ganna loosen the front or stiffin the rear at the next autocross, just to play with it .
hulkout
Apr 28, 2017 09:00 PM
Depravity
Oct 1, 2015 04:49 PM
