Adjustable toe arms
Old Sep 5, 2007 | 05:50 PM
Chad68's Avatar
Chad68
Default Adjustable toe arms
I know about the SBC camber arm and toe bolt kits but is there a company that sells adjustable toe arms other than Stillen or JIC?
The SBC kit is cheap enough (like $130 or so) and is suppose to fix the camber and toe but I've heard that those (umm dare I say cheesey) oblong toe bolts can go out of whack often, so I would like to use adjustable toe arms instead.
The Stillen arms for both camber and toe are liike 700 bucks. Does SBC make a toe arm for the Z?
Old Sep 5, 2007 | 05:57 PM
redlude97's Avatar
redlude97
you do realize that those "cheesy" eccentric toe bolts are already factory installed right? The SPC ones are just offset further to allow for more adjustment, so the stock ones would "go out of whack" just as often as the SPC ones. "toe"-radius arms are argueably one of the worst methods of adjusting toe because they change 2 planes of suspension geometry at a time.
Old Sep 6, 2007 | 12:17 AM
adrianko43's Avatar
adrianko43
+1 it's possible to change the camber using those arms, but it's not the right way.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
