Tockico D Spec shocks adjuster location?
Old Oct 26, 2007 | 04:39 PM
LeMansZCa's Avatar
LeMansZCa
Default Tockico D Spec shocks adjuster location?
I am thinking about buying a set of these with some Tein S Tech springs...
I am wondering where are the adjuster for the Tockico shocks? Are they difficult to get to when u need to adjust them? I hear rumor of drilling a hole somewehre before u can get to the adjuster???
thanks!
Old Oct 26, 2007 | 07:39 PM
Rick06Z's Avatar
Rick06Z
Old Oct 26, 2007 | 08:02 PM
JCZ33's Avatar
JCZ33
They are under the rear strut tower. You'll have to remove the plastic tops on either side of the silver Z plastic area, then use a long allen wrench to adjust.
I drilled a new hole in the metal and a parallel hole in the plastic so I would not have to remove all that stuff each time I adjust.
Old Oct 27, 2007 | 04:33 PM
LeMansZCa's Avatar
LeMansZCa
ouch! drilling the hole kinda sucks.....hum... i may have to go with those koni's
Old Oct 27, 2007 | 04:40 PM
Mike Wazowski's Avatar
Mike Wazowski
you only need to drill a hole in the metal. The plastic that covers it just pops off. no reason to drill a hole in the plastic.
This is a simple thing to do and makes adjustment easy.
https://my350z.com/forum/brakes-and-suspension-diy/249771-diy-rear-adjustment-for-tokico-d-spec-shocks.html
Old Oct 28, 2007 | 02:02 PM
LeMansZCa's Avatar
LeMansZCa
great post! the extension seems like a good idea... does it really break easily?!? or that's just an installation issue....
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
