why does my car look LOWER than other stock Z's (pic)???
Old Nov 11, 2007 | 04:47 PM
ALO8's Avatar
ALO8
you should post some pics of the hotchkis installed
Old Nov 11, 2007 | 06:58 PM
rodH's Avatar
rodH
Originally Posted by 350Zenophile
Factory Service Manuals. Check 'em.
You believe everything you read? I can look at an 03 and an 07 and tell with my own eyes side by side that they are different. Nissan seems to fib about a lot of things, I don't believe it.
Old Nov 11, 2007 | 07:00 PM
rodH's Avatar
rodH
https://my350z.com/forum/attachme...9&d=1085261348
Old Nov 12, 2007 | 06:14 AM
350Zenophile's Avatar
350Zenophile
OP, just listen to rodH. I'm sure he took things like tire and wheel sizes, tire inflation and whether or not the vehicles he was comparing were full of gas or stereo equipment when he measured the ride height with is eyes.
Oh, and be sure to spread it around the internet too b/c Nissan is intentionally misleading its techs with inaccurate factory service manuals.
Old Nov 12, 2007 | 06:47 AM
rodH's Avatar
rodH
I'd be curious is NISSAN admits that on some cars one side is actually lower than the other, or if the owners that actually have measured that measure with an inaccurate measuring tape on one side and an accurate one on the other?
Old Nov 12, 2007 | 06:51 AM
RedBullRR's Avatar
RedBullRR
Am I the only 1 who thinks it should be lowered more?!
Old Nov 12, 2007 | 09:43 AM
black06z's Avatar
black06z
The pic looks stock to me. I have a 2004 and it looks like the same wheel gap when mine was stock. The front is already low in stock form, so a set of aftermarket wheels will look great with it, but the rear could use another .75 to 1". Where's the Hotchkis pics to compare it to?
Old Nov 12, 2007 | 10:18 AM
gothchick's Avatar
gothchick
stock - get some suspension on there!!
Old Nov 12, 2007 | 10:19 AM
rodH's Avatar
rodH
here is the hotchikis pics, RIGHT after they were installed, it is lower now.
https://my350z.com/forum/attachment....9&d=1085261348
Old Nov 12, 2007 | 11:17 AM
cheshirecat79's Avatar
cheshirecat79
Looks great with the springs.
Old Nov 12, 2007 | 12:00 PM
rodH's Avatar
rodH
I like it in that pic, problem is:
1. It is lower now
2. My camber is so far off, they can't get it close and I am going through tires like bubble gum. I don't want to have to start throwing a camber kit on there, etc...
Old Nov 12, 2007 | 12:38 PM
cheshirecat79
The front should be able to get back into spec camber wise. The rear, no. A camber kit will only set you back around 200 bucks, so just bite the bullet and do it.
Old Nov 12, 2007 | 03:57 PM
ALO8's Avatar
ALO8
spc rears should me good
Old Nov 12, 2007 | 04:30 PM
ADMAN's Avatar
ADMAN
Don't listen to them. I have first run 2003 Brickyard. It is also lower than other cars, depending on the model. I noticed it when I was at the dealership back in 2003. I was parked next to a line of 350Zs, and mine sat lower than the others. But, not the track model. It was the same as mine. Touring was the highest.
I never said anything about it. Didn't really matter. Then, I switched rims and didn't give it much thought.
Funny seeing your post now...
Old Nov 12, 2007 | 04:40 PM
rodH's Avatar
rodH
It is interesting. When you see my car VS others (esp the 06+) it is lower, no matter what the manual says, not sure why I would make that up, as I have lowering springs on it right now. Maybe it was the earliest models? I got mine in Feb 03, very early production.
Old Nov 12, 2007 | 09:50 PM
ADMAN's Avatar
ADMAN
Same here. Mine was the very first run of Performance models. Something like #427 of Brickyards. (Window problems. Grease streaks. Two set of rear bearings, Gas filler tube. Tire feathering. Etc.) I know the spring rates front/back are different. And, the rear camber is different too. I've driven newer models on the track and they don't quite "sit" the same as mine in the turns.
Like I said, never gave it much more thought...
Old Nov 13, 2007 | 06:35 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Looks nice to me tho
if you don't want camber then why don't you go for other brand Springs?
about 30~40 bucks little more then Camber
Tein S-tech sounds not bad
well i'm putting on tanabe and Camber tommorow. ^^
Old Nov 13, 2007 | 08:19 AM
  #38
rodH's Avatar
rodH
what does that mean? 2 sets of rear bearings??
Old Nov 13, 2007 | 02:25 PM
  #39
ADMAN's Avatar
ADMAN
I track A LOT. Or, I used to, anyway. Wider rims/tires with the rear
camber/tow of the 2003 takes its tole on the hubs and bearings.
Old Nov 13, 2007 | 08:57 PM
  #40
black06z's Avatar
black06z
Just get the rear camber/toe kit. You could actually get one for less than $200. Im getting one this week as well.
http://cgi.ebay.com/ebaymotors/SPC-E...spagenameZWD1V
