Car has been lowered 10kg/mm....what does that mean?
Old Jun 1, 2003 | 07:16 PM
racingdynamcs's Avatar
racingdynamcs
Cool Car has been lowered 10kg/mm....what does that mean?
Old Jun 1, 2003 | 07:29 PM
React3's Avatar
React3
that's meteric measurements do a search on www.google.com for a converter from kg/mm to inches
Old Jun 1, 2003 | 07:36 PM
racingdynamcs
thx a lot
Old Jun 1, 2003 | 07:44 PM
jimster716's Avatar
jimster716
isn't that the spring rate and not the lowering height? meaning it would require 10kg to move the spring 1 mm?
Old Jun 1, 2003 | 09:44 PM
r34 racer's Avatar
r34 racer
You are correct jimster, that's a spring rate if i've ever seen one. I have no clue how you can define a lowering by a measure of spring rate; whatever it was it must ahve meant that the car's spring rate was lowered by 10kg/mm or something to that extent.
Old Jun 1, 2003 | 10:52 PM
Gsedan35's Avatar
Gsedan35
I was told to use a formula of 1Kg='s 56lbs. So,....10Kg should mean a spring rate of 560lbs. Which I do believe equals what Tein show's for the specs on the flex coilovers, they show both measurement systems. 10kg and 559lbs
http://www.tein.com/nissan.html
Old Jun 2, 2003 | 01:34 AM
apsilon's Avatar
apsilon
1kg = 2.2lbs so I don't know how that works.
Old Jun 2, 2003 | 03:47 AM
westpak's Avatar
westpak
SFZCC
It is the spring rate, it means that the spring will deflect 1 mm when 10Kg are applied, so for example a 10kg/mm spring is softer than a 12kg/mm spring.
Old Jun 2, 2003 | 03:52 AM
apsilon's Avatar
apsilon
Nevermind I worked it out. It's 10kg/mm or 559lb/inch. I didn't realise they were changing from mm to inches as well as kg to lbs.
James1990
Dec 16, 2015 08:57 PM
davidm350
Oct 31, 2015 02:28 PM
CJs_Z33
Sep 18, 2015 12:06 PM
