Sway Bars?!?!?
Old Jan 23, 2008 | 09:15 PM
GrayG35's Avatar
GrayG35
Default Sway Bars?!?!?
Ive been searching for the last 3 hours as to which sways to get for my 04 G35 coupe. It has the oem 17's and no other suspension mods. Which would be the best sways to go with and at what settings if i want the best handling through curvy roads at high speeds? Also would you all recomend getting springs and a strut bar also while im at it? what do you all think about the cobb stage 2 kit?
thanks for the help in advance!
Old Jan 23, 2008 | 09:24 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
hotchkis tvs kit would be good, springs/sways all in a matched package. High speeds w/your factory tires dont sound to good of an idea? as far as the settings you have to just play around w/it. You also may want to look at www.g35driver.com as the info you seek will prolly be there
Old Jan 24, 2008 | 03:17 AM
VIZAGE's Avatar
VIZAGE
You searched for three hours and found nothing? There was just two threads started last week along with the other 100 in the last few years stating what sways most use. The one thread of last week was a poll they states what most setting people use on there car.
You will have to start with the suppliers reconmmendatios and then test and tune of your own until you fill the setting is best for you at that time. Sorry to be so direct, but obvious this has been ask to many times already.
Old Jan 24, 2008 | 05:49 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
i just got the hotchkis from vivid racing, the quality seems solid
Old Jan 25, 2008 | 07:11 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sway bars would be wasted assuming you are running stock tires...those should be your first upgrade
Old Jan 25, 2008 | 08:52 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
ya
stock tires are not only crap but dangerous in rain.
Old Jan 25, 2008 | 08:56 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
also...get a strut tower bar before getting sways its cheaper to buy and $0 cost to install and it will make a big improvement on ur strutless g35
Old Jan 25, 2008 | 10:14 PM
Gsedan35's Avatar
Gsedan35
To bad the G35 doesn't have the Z's special welded on front STB mounting tabs. Still haven't seen a design I would install.
Old Jan 25, 2008 | 10:20 PM
Gsedan35's Avatar
Gsedan35
Your car was delivered on oem shocks that are weaker then all oem 350Z shocks produced to date. As such they are far too weak for use on the springs that come with Cobb kit. Your much better off with the Hotchkis TVS kit in comparison. As the other's have suggested, better tires is a good idea.
Old Jan 27, 2008 | 01:36 PM
GrayG35's Avatar
GrayG35
I forgot to mention that i already had a good set of tires. i have nitto 555's all around. lol i got rid of the stock tires a long time ago.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
