hks hipermax III - unconventional spring rates
Old Feb 4, 2008 | 04:33 PM
Cloud's Avatar
Cloud
Default hks hipermax III - unconventional spring rates
For the hipermax III sport the spring rates are 11F 12R and standard hipermax III its 9F 10R.
Afaik almost all setups have higher spring rates in the front or at least the same. What could the reason be for hks using higher rear spring rates?
Old Feb 6, 2008 | 09:47 AM
Gsedan35's Avatar
Gsedan35
Oh man this is not going to be easy.
What to do based on based on so called dynamic laws of tuning/car setup.
What to do based on how certain elements of suspension design effect or alter the above (example anti dive and anti squat geometry and oem suspension bushing {deflection/compliance}).
What to do based on testing and wanting certain properties over others in spite of the two things mentioned above (example, at what point can you apply power as cornering loads begin to ease). And I will add in the possiblity that some may not watch or chase proper dampning control as this may effect their rate choices.
Look at say a 10 car field of 350Z's (Fairlady) campaining in what I guess are a few different spec races in Japan and look at their suspenison specs. You will not find common ground, some will be on front biased setups, some will be on equal bias setups and some will be on rear biased setups.
Remember, spring rates are one thing, what really matters is how much of the springs power actually makes it to the wheel, we call that number wheel rate.
Originally Posted by hippie
The motion rates (as I measured and averaged them over full travel) are.... .688 F and .649 R (measured at center of spring)
Math example
616 X .688 X .688 = 292
672 X .649 X .649 = 283
Hks Hypermax III Sport
Spring rates 616/672 (wheel rates are 292/283)
Hks Hypermax III
Spring rates 504/504 (wheel rates are 239/212
2003/2004 oem 350Z
Spring rates314/342 (wheel rates are 149/144
2004.5/2007 oem 350Z
Spring rates 314/427 (wheel rates are 149/180)
Just for fun
Tein Mono Flex
784/784 (wheel rates are 371/330
Zeal XS with springs in oem locatoin
560/448 (wheel rates are 265/189
Zeal XS with springs on rear dampner (true coilover)
560/448 (wheel rates are 265/448 {because rear lower mount is attached diirectly to the wheel hub})
Stance GR+ with springs on rear dampner (true coilovers)
672/280 (wheel rates are 318/280
Stance GR+ with springs in oem location
672/616 (wheel rates are 318/259)
Stance GR+Pro springs in oem location
896/784 (wheel rates are 424/330
Ohlins PCV or DFV
560/392 (wheel rates are 265/165
TcKline DA shocks with Nismo T2 springs
Spring rates 690/690 (wheel rates are 327/291
Truechoice Phase III/IV coilovers
Spring rates 500/425 (wheel rates are 237/179
Old Feb 6, 2008 | 11:55 AM
terrorist22's Avatar
terrorist22
Wheel rate = wheel "spring" rate? Does this also take into account the rate of the tires you choose?
Old Feb 6, 2008 | 03:16 PM
Gsedan35's Avatar
Gsedan35
No. Without writting a book. Each given setup above shows you the spring rates. But, that doesn't show you how much of the springs power actually makes it to the wheel for perform work. Seeing the wheel rates, is seeing that number, how much of the springs power makes it to the wheel. Numbers shown are in the same format as the spring rates, lbs per inch.
I've never heard of tire choice being a factor in wheel rate.
Old Feb 25, 2008 | 10:52 PM
Alang35's Avatar
Alang35
i think those springrates might be wrong...
Originally Posted by Sharif@Forged
Spring rates on the Hypermax III street is 9F/9R, and Hypermax III Sport 11F/12R.
Old Feb 26, 2008 | 12:05 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
So let me get this right. Theoretically, two coilovers of different brands A and B. A has a spring rate of 12, and B has a spring rate of 10. A could still "feel" softer than B because it's wheel rate could be made lower than A?
So then buying a coilover for comfort, based on spring rates is going to be a bit of a cackhanded afair!
Old Feb 26, 2008 | 05:17 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
comparing 2 different coilovers based on spring rates has always been useless as **** on a bull.
Old Feb 26, 2008 | 06:22 AM
Q45tech's Avatar
Q45tech
Important to analyse the ratio between fore and aft springs to optimize the ride otherwise you get serious pitching and undulation on highway at different speeds based on wheelbase and chassis stiffness.
As springs get stiffer the amount of tire sidewall stiffness becomes less material.
Old Feb 26, 2008 | 07:33 AM
Motormouth's Avatar
Motormouth
I notice that the wheel rates rated on your setup are midfield in the 2-300s, while some are much higher.
wheel rates still don't tell you how much grip you have since it doesn't take into account rebound dampening over bumps, etc correct?
What are you trying to show with the wheel spring rates? what does it mean to me when I am shopping for a coilover setup.
thanks.
Old Feb 26, 2008 | 08:31 AM
Lawn Dart's Avatar
Lawn Dart
Yep, HKS lists the standard Hipermax III as 9f & 9r.
Old Feb 26, 2008 | 11:05 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Everywhere i post you seem to be right there busting my a$$.
Granted you can't compare coilovers just on their spring rates, but at least you get an idea of how harsh the ride might be. So what i'm saying is that you can't even do that apparently. So the only way you can find the right setup is by trial and error, which is going to be expensive, or by taking someone elses word for it. And everybody knows that no 2 people are the same. So what might be comfortable for you, might be harsh for me, and viceversa. Know what i mean?
Old Feb 26, 2008 | 11:32 AM
Motormouth's Avatar
Motormouth
you need to find out alot of info that most coilover manufacturers don't release to really get an idea of what the coilover feels like.
Old Feb 26, 2008 | 11:35 AM
Z1 Performance
Former Sponsor
clarifying a post is suddenly busting your ***? wow
thats just the thing...you really can't get any idea how the car will ride based on spring rates alone.
Yes I know exactly what you mean - everything in life is relative, from coilover comfort, to exhaust volume, to wheels being light, to tires being grippy, to a car being fast, to a restaurant having good food. That's why when you can't experience every option for yourself, you weigh the opinions of people smarter than you, or with more experience than you, and make your decisions based on that information.
Old Feb 26, 2008 | 11:54 AM
Sensi09's Avatar
Sensi09
Works Concepts
Would the sports and the regular Hiperman IIIs have the same shock valving?
Old Feb 26, 2008 | 04:29 PM
Gsedan35's Avatar
Gsedan35
Rates are pulled from HKS Japan. It has not been HKS's practice to change the rates once the product makes it to our shores, LS LS+ and II have the same spring rates here and in Japan. The RS was never listed on the HKS site in Japan.
A much more troublesome issue needs to be resolved with the III. If for the first time from HKS, Z33 application's have moved to a truecoilover setup in the rear, either posted spring rate represents far too much rear spring power at the rear wheels. IMO, get your vendor of choice to verify where the rear springs mount before buying as in they open up the box and look. I've never been impressed with whoever picks up the phone at HKS, for everyone's sake I hope they are not a true coilover setup in the rear.
Old Feb 26, 2008 | 04:32 PM
Z1 Performance
Former Sponsor
not sure where that rumor was started but its not a true coilover in the rear - it retains the same configuration as stock (ie the "right" way ), and has the spring separate from the damper
Old Feb 26, 2008 | 04:34 PM
Motormouth's Avatar
Motormouth
Gsedan, what about my question (that was for you) earlier in this post?
Old Feb 26, 2008 | 04:40 PM
Gsedan35's Avatar
Gsedan35
Your applying something in a way that you really should not. We are bringing up wheel rates for the soul purpose of showing how much spring is making it to the wheels. Yes the math will tell you things, but what it won't tell you is how well the dampners are controling said spring rate, that's something that is harder to quantify, but does seperate the men from the boys in the business so to speak.
For a comfort based coilover Tein has offered the CS for quite some time, that product and the Bilstein PSS9 would be hard to beat for someone looking for comfort. Not sure if the HKS III CLX represents a advance on comfort vs the LS, you gain full height adjustablity, but spring rates are higher.
Old Feb 26, 2008 | 05:10 PM
Gsedan35's Avatar
Gsedan35
thanks.
Correct, dampning does matter. Compression and rebound dampning both matter, if for instance I want to up my front spring rates. Even though I have seperate rebound and compression dampning in the front, I will have to have the front's revalved to lower the compression dampning level and raise the rebound at the same time.
I wanted to show the oem wheel rate baseline so owners could refer to how their car is setup now and maybe consider where a given setup may take the car, especially setups with a very high bias in the rear. My own testing agree's the Unitech team that did the R&D for Truehoice, higher level's of rear spring rate compromises rear grip on corner exit. Though in the end, your supposed to be willing to run different rates to get the car setup how you like it rate wise, then fine tune at the limit behavior with adjustable sway bars.
Old Feb 26, 2008 | 05:16 PM
jonnylaw's Avatar
jonnylaw
Is the "sport" version also not a true coilover setup in the rear like the regular hipermaxIII version and the stock configuration which have the spring and damper seperate?
