Sad day for me... Improperly installed TEIN FLEX and Rear upper mount bolt broke off.
Old Apr 9, 2008 | 10:05 PM
terrasmak's Avatar
Its a non load bearing part, sounds like a good fix.
Old Apr 9, 2008 | 10:18 PM
Eazzy's Avatar
Eazzy
This is not the first Post on this but I have not had the experience myself....If I did and it is at all possible (even if I had to cut a small square out and mig it back to get at it) Id set a new bolt with a weld washer and mig it in from the top.
Old Apr 11, 2008 | 08:38 PM
leozim's Avatar
leozim
which shop is it?
Old Dec 7, 2008 | 07:39 AM
nothix's Avatar
nothix
I just broke the same bolt last night on my Stance install.
I'm having trouble drilling out the screw.
Small bits go through fine, but once I reach a certain point it becomes impossible.
Old Dec 7, 2008 | 11:23 AM
35oZephyR's Avatar
35oZephyR
Those OEM bolts shear off easily. I would have more faith in the aftermarket bolt that was placed in there.
But like everyone else said, it will turn when you unscrew it. I would do what Chris @ Migliore did and place some JB weld on the other side of the bolt the next chance you get with the strut off.
Old Dec 7, 2008 | 01:07 PM
Beau's Avatar
Beau
I broke one off on a previous car. It happens and it's no big deal. The fix they did is just fine.
If they don't install coilovers often, or are not a performance oriented shop, they probably could care less as long as the bolts go on all the way. Most tech's are just there for a paycheck anyway, just like most people go to work. It pays the bills. If you want it done right, do it yourself. Even then, you probably would have broken the bolt anyway and been on here asking for advice on how to fix it.
Old Dec 7, 2008 | 01:21 PM
Bret86944's Avatar
Bret86944
Originally Posted by xdrius
My question is two-fold. First, would this jeopardize the structural integrity or performance of that particular rear suspension? (There is a reason why Nissan decided to weld/press the bolts there onto the chassis right?)
There isn't necessarily anything wrong with replacing the OEM bolt with the bolt they put in there. The bolt may be welded simply because it makes life easier on the assembly line.
Old Dec 7, 2008 | 01:57 PM
nothix's Avatar
nothix
went to home depot and got new bits, went through very easily
Old Dec 8, 2008 | 08:57 AM
j.arnaldo's Avatar
j.arnaldo
S-T-O-C-K 'O4 Touring Coupe: Flawless AT! NO feathering! NO oil-consumption problem!
NO miss! NO PROBLEMO!!!
Old Dec 8, 2008 | 10:28 AM
SS728's Avatar
SS728
^wat? GTFO.
But on topic, I had the same problem.
I overtorqued one of the bolts and it snapped.
I got some high strength bolts.
First I thought I had to drill out the bolt, but you don't have to!!!
Just get a hammer and start pounding, eventually the bolt's welds will come loose and the bolt will get free.
I placed the new bolt through the hole, and since it was a little bigger, I had a tough time screwing it in.
Added some locking washers, etc. And it holds just fine.
Old Dec 8, 2008 | 01:34 PM
nothix's Avatar
nothix
JB Weld worked well thanks Chris
JjL
East Canada
Jun 12, 2019 03:04 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Suffolk350z
Sep 13, 2015 02:43 PM
