Mono Flex
Old Apr 15, 2008 | 09:46 AM
ke0ki2k's Avatar
ke0ki2k
Default Mono Flex
cant find information on this for some reason. I read that the front pillow ball mounts are camber adjustable on the Mono's. Anyone know exactly how much negative camber you can run with them? says 0-3 depending on application on Teins site.
Old Apr 15, 2008 | 10:04 AM
Gsedan35's Avatar
Gsedan35
With the type of suspension design we have, you cannot adjust anything alignment wise from the upper shocks mount front or rear, it is simply impossible. As far as upper mount construction, it becomes a issue of solid metal bushings where the piston shaft goes threw the mount vs having rubber bushing inserts.
We do have several good Monoflex reviews if you haven't read them already.
Old Apr 15, 2008 | 10:08 AM
ke0ki2k's Avatar
ke0ki2k
I know i tried to find em, couldnt get ahold of em though. I thought that was the deal but all the sites said it was adjustable. thanks tho.
Old Apr 17, 2008 | 08:14 PM
Gsedan35's Avatar
Gsedan35
I used the search term "mono" and narrowed the area to search to the suspension section, here are the review threads.
https://my350z.com/forum/showthread....highlight=mono
Old Apr 17, 2008 | 08:46 PM
350POWER's Avatar
350POWER
run bc n+ just as good as it can get
Old Apr 17, 2008 | 09:06 PM
Gsedan35's Avatar
Gsedan35
Not in the same league.
Old Apr 18, 2008 | 06:55 AM
ke0ki2k's Avatar
ke0ki2k
seriously lol. the only time i'll take a comment like that into account is if its someone who has actually raced on Mono's, Ohlins, JIC's, Zero2's, Stance pros, BC's, etc. and prefers the BC's...not someone who just threw some BC coilovers on his car and assumed that because the car felt "different" that it handled better.
nanotech
Oct 2, 2015 05:02 AM
SirZaLot
Nov 13, 2003 09:49 PM
Ricky
Nov 28, 2002 12:54 PM
