what else suspension?
Old May 27, 2008 | 11:30 PM
ForumArty's Avatar
ForumArty
Default what else suspension?
so i have decided to get a pair of BC coilovers and was wondering if i should get anything else to help my suspension. just want to know what others did and what you guys think. thanks!
Old May 27, 2008 | 11:51 PM
black06z's Avatar
black06z
Front and Rear Camber/Toe kit.
Old May 28, 2008 | 01:25 AM
terrasmak's Avatar
Swaybars
Old May 28, 2008 | 08:40 AM
mistico's Avatar
mistico
If you'll be lowering the car you'll eventually need more parts than you think.
- camber arms F/R to get the numbers you want
- sway bars are nice to have
- If you get stiffer sways and lower the car, you'll need endlinks because the stock ones can't handle the angle/load. I belive it's mostly the front ones but I changed F/R anyway.
It's like anything else, once you change something, you end up having to change other parts because of it.
Old May 28, 2008 | 09:17 AM
Gsedan35's Avatar
Gsedan35
^+1
But I'd suggest that you could get a better coilover. Cusco Zero2 for $1050 shipped. https://my350z.com/forum/suspension/360361-cusco-zero-2-suspension-and-volk-gt-m-wheels.html
Old May 28, 2008 | 07:04 PM
turismo's Avatar
turismo
Originally Posted by Gsedan35
^+1
But I'd suggest that you could get a better coilover. Cusco Zero2 for $1050 shipped. https://my350z.com/forum/showthread.php?t=360361
Whats wrong with BC coilovers? Just asking since Im looking to replace my D2's
Old May 28, 2008 | 10:01 PM
ForumArty's Avatar
ForumArty
thanks for all of your help guys! this is exactly why i asked.
Old May 28, 2008 | 11:54 PM
Gizmo0803's Avatar
Gizmo0803
just a suggestion...as mistico stated, you'll have to change out a lot of things when buying coilvers, but this isn't the case if you go with the nismo s-tune suspension. You could have pretty good handling AND you can be worry free about replacing camber arms, end links, etc. The downside is that you can't adjust the height of your ride with the nismo, and the drop that you do get isn't very substantial (0.6 inches all around).
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
