adjusting rear damping?
Old Jul 14, 2008 | 12:17 PM
azn_sean's Avatar
azn_sean
Default adjusting rear damping?
Hi all, I had installed my Stance coilovers w/ oem style rear on my 350z. After driving it for a couple of days, the car hops like crazy, so I went ahead nad adjust the front. Here's my problem, I'm a noob when it comes to the Z, I know the rear adjuster is on the top of the damper like the fronts, so I ripped apart the carpet and plastics in the trunk, I STILL CAN'T FIND A WAY TO GET TO MY COILOVER!! Am I suppose to take apart the huge metal piece? There has to be an easier way...can some one show me how?
Thanks in advance
Old Jul 15, 2008 | 08:24 AM
SchismX's Avatar
SchismX
Drill a hole?
At least I believe that is what some of the other members here have done.
Old Jul 15, 2008 | 08:43 AM
SpoilsofWar's Avatar
SpoilsofWar
Yep, I used a holesaw and cut a hole thru the rear strut brace on both sides, so I can get to the adjustment ***** on my coilovers.
Old Jul 15, 2008 | 10:36 AM
terrasmak's Avatar
I got extenders with my Bc's , nice and easy to adjust. You may be able to get a set from BC , just check with then and see if they will fit yours.
Old Jul 16, 2008 | 11:37 AM
azn_sean's Avatar
azn_sean
thanks guys for the replies.
