Need help!!
Old Jul 14, 2008 | 06:25 PM
ssangjjang83's Avatar
ssangjjang83
Default Need help!!
I just inspect a my 350z and said that my rear link is bented....
which it will cost me about $600-$700 from dealer.....
someone told me that just get a good sway bar and there will be no problem..
so what's the best option to me to fix my car???
should i just get good sway bar or just replace a rear link??
if i want to replace a rear link myself....is it hard to replace it????
Old Jul 14, 2008 | 07:03 PM
The Captain's Avatar
The Captain
If it's just the sway, it's easy to replace and a lot cheaper to buy an aftermarket one to dyi.
Old Jul 14, 2008 | 07:05 PM
2ndname's Avatar
2ndname
How did you rear link get bent? Accident or faulty part that was never replaced that caused this?
Old Jul 14, 2008 | 07:16 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Jul 14, 2008 | 07:17 PM
ssangjjang83
i got it from used car lot at dealer...and of course i didn't know it was bented..
when i found out, dealer told me the warranty is only on powertrain.....
which is not cover by warranty....
and the reason why i went to shop again is, i ran over the f***ing big bump and makes grinding sound.....sounds like tire problem...and went to shop, my another link(left side)is bented....hate to drive in washington state...always having construction all over the road!!! anyway..plz help me choose....do i have to change a rear radius arm??or get a sway bar?
Old Jul 14, 2008 | 07:21 PM
R-TuneZ's Avatar
R-TuneZ
Squeaking brakes
instead of
Help
+1.
Old Jul 14, 2008 | 07:24 PM
2ndname's Avatar
2ndname
Originally Posted by R-TuneZ
+1.
If your rear link is bent, repair the rear link.
Sure you can go take a shortcut, but if it's bent, it's bent, no sway bar is going to straighten it out.
Just call a different mechanic to confirm that it is a rear link before you drop the cash.
Old Jul 14, 2008 | 07:44 PM
R-TuneZ's Avatar
R-TuneZ
+1, its as simple as that. try going to a private mechanic, as opposed to a dealer, they usually will not charge you to look at something and give you an estimate. don't be lazy about it, its a Z. not a f*cking civic.
Old Jul 14, 2008 | 08:22 PM
ssangjjang83
if they are talking about link...is it either radius arms or control arms??
because i went to 2 mechanic shop today...
1 said no problem and 1 said radius arms.....
sorry to bother u guys but help me out pplz!
Old Jul 14, 2008 | 09:05 PM
R-TuneZ's Avatar
R-TuneZ
i am not sure what you are asking. can you post pics of the allegedly damaged part? otherwise we are just guessing and wasting everyones time.
