Is This From Negative Camber? Puzzled
Old Jul 17, 2008 | 11:51 AM
j.arnaldo's Avatar
j.arnaldo
From other posts I've read, POSITIVE CAMBER is best for our monZters.
VO...'s Avatar
VO...
Administrator
IMO , you got a bad tire.
+1. I don't think any amount of negative camber could goudge your tires out like that. Hell, the wheel would have to be mounted horizontally to get enough negative camber to do that...
Old Jul 17, 2008 | 01:04 PM
SchismX's Avatar
SchismX
You couldn't have said it any more WRONG! Our Zs come from the factory with negative camber if that tells you anything.
Old Jul 17, 2008 | 01:58 PM
saberphx's Avatar
saberphx
+1 on bad tire, negative camber doesn't do that. (obviously it couldn't have helped, but still couldn't have caused.)
Old Jul 17, 2008 | 02:50 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
So you like driving farm tractors huh?
Old Jul 17, 2008 | 04:26 PM
terrasmak's Avatar
You can't forget the 15 degrees of toe out to help with that wear pattern.
Old Jul 17, 2008 | 04:29 PM
AVmagneticZ's Avatar
AVmagneticZ
not camber garunteed
Old Jul 17, 2008 | 05:24 PM
TreeFiddyZee
Do WHAAAAT!?
Sounds like the car I wrecked when I was in college. I played Dukes of Hazzard with a station wagon (not on purpose). The wheels were at full negative camber and full toe out. My dad drove it home squealing through the main streets of my hometown. It's pretty bad when you can stand at the front of the car and see the inside of the tires. Hey, but the tread wasn't cutting. (sorry!)
Old Jul 17, 2008 | 06:06 PM
whitecel's Avatar
whitecel
LOL guys. I had my bro-in-law put in on a lift and inspected the crap out of it.
Conclusion: He thinks it has something to do with either a crap tire or I hit something mean on the road. He told me the camber/toe is barely noticeable so it definitely couldn't be that. He also couldn't find any wear on any of my suspension components. So basically he said the tire is usable, but better safe than sorry...replace it.
Old Jul 18, 2008 | 09:08 AM
Asterix's Avatar
Asterix
That tire damage is not from any misalignment. Maybe you picked up some trash that got hooked up in there but fell out later. When you inspected it, did you use a lift that kept the car on it's tires or one that lifted by the body, leaving the wheels hanging? I'd go for a lift with it on the tires (like an alignment lift) to make sure there's no bent bracket in the way.
Asterix
Old Jul 18, 2008 | 09:44 AM
SchismX's Avatar
SchismX
They already had it on a lift to check for any suspension rubbing and what not. It had to have been something that he ran over in the past. I doubt it was a tire defect.
Old Jul 18, 2008 | 10:17 AM
VO...'s Avatar
VO...
Administrator
Put it up for sale in the classifieds...
Old Jul 18, 2008 | 10:33 AM
The Milkman's Avatar
The Milkman
That looks more like the tread patch band is separating from the rest of the tire carcase. OTR trucks w/ bad recaps will look similar to that sometimes. Also quite possible your toed-out more than needed and that is causing drag on the inside portion of the tire.
Just my 2 cents.
Old Jul 18, 2008 | 01:02 PM
WTX350Z's Avatar
WTX350Z
as many others have said "NOT CAMBER" anyone who disagree's w/ that is a moron.
It appears to be (as stated previously)
1.bad tire
2. road hazard found your tire. (I'm betting on this)
but no, not camber.
you do a burnout on/next to a steel plate?
Old Jul 18, 2008 | 01:14 PM
OldDirty Z33's Avatar
OldDirty Z33
mmmmm. IMO i think you got a bad tire, and the road conditions didn't help.. I would call your tire company to see if they can help. maybe they had a bad batch.
Old Jul 18, 2008 | 01:17 PM
whitecel's Avatar
whitecel
I wish I could. I bought the rims/tires from another member on here. O well, I'll just buy a new tire
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
