Stop Tech dilemma!!
Old Aug 9, 2008 | 09:16 AM
XM 1's Avatar
so i checked today if everything´s right....and took her out for another test ride.everything works fine-->no more "fluid"
there´s still another little problem, but should be easy to be solved.
the left front caliper seems to have some "problems" to open back again on it´s own.i´ll bleed both front calipers tomorrow or monday...so no driving for me this weekend anymore
Old Aug 9, 2008 | 02:14 PM
Chebosto's Avatar
Chebosto
scratches on rotors, where? surface of the rotors or edge?
scratches on calipers, where? top bottom, etc?
leaky calipers? Imho.. probably due to improper bleeding and/or installation. no offense. i've installed 5 sets of bbks (stoptech and other companies) and i've never had a leaky caliper as long as it was bled correctly and the bolts to the lines were properly seated correctly.
did u raise the calipers up 90degrees to get all the air out?
Old Aug 9, 2008 | 03:28 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Mine did the same thing after i bled them....it could be brake fluid left in the top of the bleeders leaking down while driving.....i used compressed air to clean out the tops of the bleeders after i bled them and it stopped...
Old Aug 10, 2008 | 05:49 AM
XM 1's Avatar
it was just the way erik told me.was rust imhibitor from the rotors.
scratches/dents where on the calipers..
Old Aug 10, 2008 | 05:58 AM
JETPILOT's Avatar
JETPILOT
Post pics of scratches/dents.
Old Aug 10, 2008 | 11:23 PM
XM 1's Avatar
allready installed so it´s quiet impossible to snap some pics.but the "dents" where on the under side of the caliper(s)
Old Aug 11, 2008 | 08:15 AM
VO...'s Avatar
VO...
Administrator
+1. I do this before the bedding process. Learned it the 2nd time around....
Old Aug 11, 2008 | 09:46 AM
dklau33's Avatar
dklau33
So you didn't follow Stoptech's direction to wash the rotors with warm water and soap prior to installation?
Step 5
Install AeroRotor Assembly
AeroRotors MUST be cleaned with soap and water prior to installation. Not doing so will damage
the rotors and pads, and will prevent the brakes from performing properly.
Warning: Do not skip this step!
Even though the rotors may look clean, the rust
inhibitor is in place, and it must be removed.
Not cleaning the rotors will severely impact the
performance of your new brake system
Old Aug 12, 2008 | 02:58 AM
XM 1's Avatar
washed it down!!!!! what i was trying to was that it could maybe be that there´s some rust inhibitor on the inside of the rotors`!?!? but it´s equal that "problem" is solved.....but i´ll def have to bleed the brakes once again....but since it´s raining agaaaaain this may take some while.
Old Aug 12, 2008 | 07:47 AM
VO...'s Avatar
VO...
Administrator
Jesus man, where do you live, in the Rainforest? It's been raining since you started this thread...
Old Aug 12, 2008 | 11:46 PM
XM 1's Avatar
sad but true that´s one main reason why i want to live somewhere else
but it seems like it´s going to be shine day....maybe i could bleed them today
Old Aug 18, 2008 | 06:32 AM
XM 1's Avatar
so it seems like everything worked out good in the end...bleeded the brakes another time....still a little issue with the rears but not a big one (still loosen some brake fluid on the bolt where u bleed the caliper....just can´t remember the english word for it )......man i´ve to post up some pics finally .....but i´m a little bit lazy right at the moment and have another new project on the start i´ll def post pics asap
Old Aug 18, 2008 | 07:48 AM
VO...'s Avatar
VO...
Administrator
I'm glad everything worked out.
En Ingles se llama "Bleed Valve".
Post pics when you can...
Old Aug 18, 2008 | 10:46 AM
dklau33's Avatar
dklau33
Glad things are working out. I just bled my front ST-40's this weekend due to a small amount of air bubbles buidling up from my last track day. No problem, no leaks, and now my pedal is very solid again ready for the next HPDE.
Old Aug 19, 2008 | 10:17 AM
XM 1's Avatar
maybe not the best...but here are some pics i took the other day (cell phone pics)
Old Aug 19, 2008 | 11:18 AM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default Wow...
looking really good there. Keep it up.
Also, I sent you my address. Why haven't you sent your brembos to me?
Old Aug 19, 2008 | 12:03 PM
XM 1's Avatar
i must had forgotten that i wanted to give them away
thx for kind words
Old Aug 21, 2008 | 07:21 AM
  #38
XM 1's Avatar
still having some issues with the front driver side caliper
don´t know why??? as i told i bleeded the hole system again and there where no bubbles at all.did 2 test drives "normal" driving conditions.
so i thought it would be a good idea to go up the mountians and have some fun
everything was fine....except the loose pedal feeling....not awlays, just sometimes (didn´t figured out under which driving conditions..????).you know you push the pedal the first time and it feel kind a loose ,then u push it another time and you could feel that the pedal feel is pretty tight.
so i drove home and tried to messure the temp. on the front calipers (since the rears didn´t even get warm )and the right caliper/rotor were hotter than the left one. ?????? could be caused by a grinding "brake pad"....which means that the pistons come out and stay out instead of going back into "open" position.
sucks pretty hard.......i´m already pissed again!!!
anyone any ideas what else could be wrong???
oh and yes the temperatur on both front calipers were the same after i bleeded the system again.
but what´s most bothering me is that it´s sunny outside and pretty good weather.....after 3 weeks of rain....and i´m sitting at home trying to figure out what´s wrong.....cause i don´t want to damage my front rotors.
Old Aug 21, 2008 | 07:31 AM
  #39
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
The way you describe the pedal feel it sounds like there is air in the lines.
Are you in South America somewhere?
Old Aug 21, 2008 | 02:34 PM
  #40
dklau33's Avatar
dklau33
When you went up to the mountains did you take some hard turns? If so you probably experienced what is known as pad knock back.
http://www.stoptech.com/tech_info/wp_knockback.shtml
