Pics of rear camber arm
Old Aug 10, 2008 | 10:12 PM
CKY881's Avatar
CKY881
Default Pics of rear camber arm
Hi, im planning on buying some aftermarket rear camber arm and toe arm, and i want to be able to ID them before I buy to make sure im buying the correct parts. Can anyone please post pics of the rear camber arm and toe arm? One of the parts im buying looks like this :
Im not sure if that's the camber arm or the toe arm.
Also a question for people with SPC rear camber kit. When you adjust the toe, are you adjusting it only the SPC toe bolt, or the entire toe arm?
Old Aug 11, 2008 | 05:02 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why not just continue the thread you already had going?
no one can tell you what piece that is from the pic as the camber arms and toe arms look the same, just vary by length...why don't you ask the manufacturer.
SPC is a toe bolt and a camber arm
PS - those cheesy endlinks are going to end up making a ton of noise....those look very cheaply made
Old Aug 11, 2008 | 06:45 AM
JETPILOT's Avatar
JETPILOT
Toe arms don't work. I never understood why suspension companies made toe arms as toe can't be properly adjusted from that location. You need the toe bolts already mentioned. And those ends are cheap on those rods. Look into Battle Version camber arms. The rod ends are very high quality and teflon lined. Never need replacing.
Old Aug 11, 2008 | 07:19 AM
Z1 Performance
Former Sponsor
I don't know if I'd go so far as to say they don't work, because they absolutely can...but it takes alot more time to align the car using 2 adjustable arms vs an arm and a toe bolt, and, you have a much narrower window of adjustment range in order for both camber and toe to be set. Given the complexities involved, I'd agree, the camber arm/toe bolt is a far easier, less expensive, easier to work with solution
Old Aug 11, 2008 | 11:47 AM
redlude97's Avatar
redlude97
You also affect the rear "caster" with the "toe" arms also though, which IMO means that they don't "work" in changing just toe as they lead people to believe. Toe bolts are the only way to go(or battleversion toe arms for true coilovers or SPL replacement spring buckets)
Old Aug 11, 2008 | 11:57 AM
Z1 Performance
Former Sponsor
yes caster is affected too...by how much though depends on the car itself and the setup. I recently had an alignment done, 25 inch rear height from top of wheel well to the ground, 10 inch rear wheels, +14 offset, 285/30/19 RE050A's, 0 rear toe, down to 1.5 degrees camber, and caster is still in factory spec - but it took me an hour per side to do
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
