Searching: BBK Stoptech Performance/less weight
Old Aug 15, 2008 | 06:56 AM
Germanguy's Avatar
Germanguy
Default Searching: BBK Stoptech Performance/less weight
Hi,
I'm looking around for the best relation of performance/less weight bbk from Stoptech.
I thought about 4 piston 14" front, 4 piston 13" rear.
What do you think?
I've searched!
Thanks for answers.
Alex
Old Aug 15, 2008 | 07:33 AM
JETPILOT's Avatar
JETPILOT
For weight savings go with the ST-22 2 piston 328 rear. It should be good for your needs. I am using the ST-40 front caliper and the OEM Brembo rear which uses the same pad as the St-22 and it holds up well for me on the track. The rear pads are very small and wear out quickly. You might consider going with the ST-45 4 piston 355 rear like you said just for the increased pad size for longevity. But if weight is your biggest concern, the 2 piston ST-22 328 is what you want.
Old Aug 16, 2008 | 05:41 AM
Germanguy's Avatar
Germanguy
Hmmm, I dont like the 2 piston look. But, thanks for the idea.
How much would weight difference between 13" 4 piston rear and 328mm 2 piston rear?
What do the others think about 4 pist 14" front, 4 piston 13" rear?
Old Aug 17, 2008 | 08:18 AM
Germanguy's Avatar
Germanguy
bump what do others think about:
Stoptech 4 pist 13" front, 4 pist 13" rear
Stoptech 4 pist 14" front, 4 pist 13" rear
Old Aug 17, 2008 | 09:45 AM
JETPILOT's Avatar
JETPILOT
I don't think they make a 4 piston 13" rear. I think they only make a 355mm 4 piston rear.
Are we doing this to be fasionable or for performance?
Old Aug 17, 2008 | 10:13 AM
Germanguy's Avatar
Germanguy
1. https://my350z.com/forum/brakes-susp...thread-16.html
page 16, comment 302 -> he has 13" in rear
2. A mix of both
Old Aug 17, 2008 | 10:24 AM
thinking's Avatar
thinking
That is on a Dodge Viper
Old Aug 17, 2008 | 10:40 AM
Germanguy's Avatar
Germanguy
Thanks.
Old Aug 17, 2008 | 11:01 AM
JETPILOT's Avatar
JETPILOT
Stoptech catalog states there is a 355 4 piston app or a 328 2 piston app.
Old Aug 18, 2008 | 03:20 AM
Germanguy's Avatar
Germanguy
ummpf, I think I'm going 2 piece 13" rear. They look much bigger than I thought.
What do you drive front? 4 piston... 14" or 13"?
Alex.
Old Aug 18, 2008 | 06:58 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
here's my stoptech 14" 4pot front and 14" 4pot rear, I can place them on the scale and weigh them for you. The calipers on the front looks exactly the same as the rear in my eyes, I don't see any difference, the only difference is the length of the steel braided brake lines
Attached Thumbnails Searching: BBK Stoptech Performance/less weight-may2008023.jpg   Searching: BBK Stoptech Performance/less weight-may2008024.jpg   Searching: BBK Stoptech Performance/less weight-may2008025.jpg   Searching: BBK Stoptech Performance/less weight-may2008027.jpg
Old Aug 18, 2008 | 07:38 AM
Germanguy's Avatar
Germanguy
DO it!
Thanks!
Old Aug 18, 2008 | 08:10 AM
TRYNALIVEPRO
can anybody tell me why stoptech say the rear are for track use only???
Old Aug 18, 2008 | 08:14 AM
Germanguy's Avatar
Germanguy
Because if you push your brake pad, your brakes could stop a tank!
Old Aug 18, 2008 | 12:23 PM
TRYNALIVEPRO
lol lol
Old Sep 10, 2008 | 06:23 AM
TRYNALIVEPRO
they weigh about 29lbs each
Old Sep 10, 2008 | 01:02 PM
got556's Avatar
got556
And how much do OEM Brembos weigh? OEM Non Brembos?
I think this would make a good sticky if we could get weights of each of the kits out there.
Old Sep 10, 2008 | 09:36 PM
KhanMan's Avatar
KhanMan
That is a good question. However, isn't the 2006 non-Brembo model and up using a different setup than the previous years?
Old Sep 14, 2008 | 04:20 PM
bbs350z's Avatar
bbs350z
+1 seeing as the front brakes do over 70% of braking, id feel that a 2 piston rear is more than adaquet? im running the stoptech 355 up front, and stock single pistons rears (upgraded pads and ss lines) and i feel thats enough for a good track day (although i wanna go rear bbk in the future)
Old Sep 18, 2008 | 01:05 PM
ADMAN's Avatar
ADMAN
+1 not needed that much stopping power in the rear on the track.
Looks extra bling if you're a waxer, though.
