which spc camber kit to buy?
Old Aug 15, 2008 | 04:35 PM
g_spek's Avatar
g_spek
Default which spc camber kit to buy?
72050 - rear camber arm and toe bolts (Camber ±4.00 degree Toe ±3.00 degree)
72055 - rear camber and toe bolts only (Camber ±3.00 degree Toe ±3.00 degree)
will getting camber and toe bolts be enough to bring the rears back to spec? curious cause buying the bolts only will cost about $65 compared to the camber arms at about $150. ....thanks in advance.
Old Aug 15, 2008 | 06:22 PM
eltness350's Avatar
eltness350
The Untouchable
i think just the bolts will get u back to stock spec...bump for more info and how low is your drop?
Old Aug 15, 2008 | 07:29 PM
Z_Nick_Z's Avatar
Z_Nick_Z
well its hard to get the camber and toe into spec without the camber arms and toe bolts together. Depending on your drop, you will definitely need both installed
Old Aug 16, 2008 | 08:21 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
click our sig - we have the Eibach rear camber/toe kit in stock and on sale - exact same kit as the SPC (made by SPC in fact), just cheaper
Old Aug 19, 2008 | 09:05 AM
g_spek's Avatar
g_spek
sorry for the late reply, forgot i had this thread. anyway i have the eibach sportlines so it is a 1.2" drop. i was thinking the same thing that the bolts should suffice cause it is only a +/- 1.00 degree difference.
how off were your cars' camber?
Old Aug 21, 2008 | 05:51 AM
Z1 Performance
Former Sponsor
Sportlines drop a car more than the advertised drop
the only way to know how much correction you need is to do a before/after alignment spec check
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
