Moonface Roll Center Adjusters
Old Nov 6, 2008 | 11:50 AM
  #61
JETPILOT's Avatar
JETPILOT
The moonface roll center adjusters do move the pivot point where the lower control arm connects to the hub. If you shorten the distance between the lower control arm and the hub which the shorter adjuster do then you will need to legnthen your damper to keep the same ride height. By legnthening the damper you are changing the angle between the outside hub pivot point and the inside chasis pivot point. You are also changing the angle of the upper control arm since bothe arms are connected by the upright. The change in angle of the 2 control arms raises the instant center and therefore the roll center.
Old Nov 6, 2008 | 12:04 PM
  #62
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Yes...
No, your upright is always in the same position relative to the ground, and if your ride height remains the same, your chassis remains in the same position relative to the ground. The pivot points are fixed on the inboard, relative to the chassis, and on the outboard, relative to the upright. So nothing is changed.
The upper arm pivot points would remain fixed for the same reason above...
Old Nov 6, 2008 | 12:16 PM
  #63
laze1's Avatar
laze1
Dayum this is an interesting thread...for real..
I might even learn something from a Forum Thread
Old Nov 6, 2008 | 12:28 PM
  #64
JETPILOT's Avatar
JETPILOT
Originally Posted by kuah@splparts.com
Yes...
Yes....You're right. The upper control arm angle won't change.
Last edited by JETPILOT; Nov 6, 2008 at 02:05 PM. Reason: Deleted incorrect information
Old Nov 6, 2008 | 01:41 PM
  #65
bimmertech's Avatar
bimmertech
so kuah, what do you and the gang at SPL have up your sleeve for the front geometry--if you even feel there is anything to gain there?
Old Nov 6, 2008 | 02:04 PM
  #66
JETPILOT's Avatar
JETPILOT
I just got a call back from a firend who has a suspension program and the program confirms what you are saying Kuah. These will not change the roll center at all. After studying the suspensuion in the garage I see what your saying.
So am I right that these won't roll center? $500 for parts that don't work?
Old Nov 6, 2008 | 02:12 PM
  #67
kuah@splparts.com
Well there's always something to be gained, I don't think any racer will stop looking for that last edge We did recently release the outer tie rod ends for bumpsteer adjustment, but otherwise progress is slow, I have ideas but not enough time/resources for development. Right now we are working on the v2 front upper arms, hopefully next year the economy will turn around and we can really get going with new products
Old Nov 11, 2008 | 04:13 AM
  #68
Colin_S's Avatar
Colin_S
Jet,
Do you not think these made any difference at all? I can't really comment on roll centre, but my handling definitely changed for the better upon fitting these.
Old Nov 11, 2008 | 04:19 AM
  #69
Beau's Avatar
Beau
I think if the coilover needed to be extended, then it obviously moved the arm and changed the geometry. If you are noticing a dramatic difference, it certainly works.
Old Nov 11, 2008 | 04:30 AM
  #70
rrmedicx's Avatar
rrmedicx
But didn't you get an alignment after installing these moonface devices? Don't you think the alignment had any effect at all??? Maybe you were so far out of spec that you didn't know until now that you are back to spec??? Just a thought.
Old Nov 11, 2008 | 08:16 AM
  #71
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Post
I know I just had these installed on my own car ~2 weeks ago. My alignment had previously been done in May, just before Z days.
My before and after alignment specs.
May 2008 Specs
Front
Camber - Final (after alignment done May '08)
FL FR
-1.5 -1.6
Toe - Final (after May '08 alignment)
FL FR
.000 .001
These were my specs when the car was put on the rack October 2008
Front:
Camber - Initial (before RCA kit installed, before corner balancing done)
FL FR
-1.59 -1.64
Toe - Initial
FL FR
.004 .006
Camber - Final (after installing the RCA kit, camber and toe both had to be readjusted, this is where my car sits now)
FL FR
-1.29 -1.45
Toe - Final
FL FR
.003 .002
Cusco camber arms (set to max positive both sides, unmodded) , HKS RS coilovers. I think I posted front height from centerline to ground earlier in this thread so you can see what height I'm at.
Old Nov 11, 2008 | 08:55 AM
  #72
rrmedicx's Avatar
rrmedicx
Adam, are these adjustments made with you in the car? That would explain the differences I see in the Left to Right comparo.
Old Nov 11, 2008 | 08:58 AM
  #73
Z1 Performance
Former Sponsor
I wasn't in the car, someone else there was who's basically same weight as me. Keep in mind though that the Cusco arms have fixed adjustment points, its not like an open slot. So, it sorta ends up where it ends up - so not uncommon for there to be small differences side to side
Old Nov 11, 2008 | 10:38 AM
  #74
Colin_S's Avatar
Colin_S
Yea I did, but had a few days before i had the alignment where i noticed a dramatic difference.
Old Nov 11, 2008 | 01:34 PM
  #75
guitman32's Avatar
guitman32
Now we're talking. This is exactly the kind of discussion that people should push for before taking the jump.
I would comment but the discussion between Jet and Kuah is very thorough. Interested to see further developments.
Old Nov 12, 2008 | 05:12 AM
  #76
rrmedicx's Avatar
rrmedicx
Could you elaborate on your findings just a bit more perhaps? It was "better" just doesn't cut it for me... Please explain what your car was doing wrong before the mod and how the mod helped.
Ex. Every time I made a sharp 90 degree turn > 20 mph the tires would squeel and now it hooks likes its on rails. etc..
Old Nov 12, 2008 | 10:53 AM
  #77
Colin_S's Avatar
Colin_S
Sorry i can't be more technical but for me my front end was very 'twitchy' which i believe is bumpsteer. The faster i was going, the more noticeable it was. My front end seemed to dance about all over the place over rough ground which was instantly eliminated after fitting these. I could instantly drive faster and under more control, long sweeping bends which i previously could only take at 100mph now was comfortably taking them at 140mph. (albeit i could take them at 140 on standard suspension).
Also i was experiencing understeer on rough ground where i was pretty netural on a smooth surface which has also disappeared.
The turn in response is much sharper at all speeds and the car overall seems very precise.
Ultimately i am very happy with these and would recommend them to anyone who's car was handling like mine.
Hope that helps.
Old Nov 12, 2008 | 11:25 AM
  #78
rrmedicx's Avatar
rrmedicx
Thanks for breaking that down. That makes much more sense. I appreciate it. Are you using sway bars at least, because for a stock suspension, that a pretty aggressive pace 140 mph.
Old Nov 12, 2008 | 11:48 AM
  #79
Colin_S's Avatar
Colin_S
No probs,
Oh i am running a full setup now, Tein Flex Coilovers, Hotchkis Sways, Custo A Arms, SPC Rear Camber and Toe Kit, Power Grid Endlinks and these Moonface things.
Old Nov 12, 2008 | 03:09 PM
  #80
rrmedicx's Avatar
rrmedicx
So from what I gather Colin, the moonface upgrade was your last and most recent suspension mod, afterwhich you noticed an immediate change which was further improved after you got your alignment checked/corrected. Thank you.
Question: did the powergrid endlinks do anything for you? I am suspicious about those too.
Another waste of $$$ or useful mod? Curious about your (or anyone's) feedback on those too.
