Need help asap
Old Sep 20, 2008 | 07:41 AM
THe Emperor's Avatar
THe Emperor
Default Need help asap
One of my studs broke off and I'm removing the rotor to change them. I have the actual caliper off but the part that holds the pads is still on there. How do I remove this piece?
Old Sep 20, 2008 | 07:56 AM
Kwame's Avatar
Kwame
I'm a little lost.
If the caliper is "off" as you say and by definition its function is to hold the pads in place and position them against the brake rotor, how is the part that "hold the pads" still on the hub?
Maybe you don't have the caliper "off" you just have it open. In that case there are two bolts on the backside of the caliper that fasten it to the hub. Remove those two bolts and the entire caliper should slide off of the rotor but it will still be connected to the car via the brake line. I hope this helps.
Old Sep 20, 2008 | 07:58 AM
THe Emperor
OK. I have the calipers open. I removed the two 14mm bolts on the back, so should I just force that second pieice off?
Old Sep 20, 2008 | 08:03 AM
THe Emperor
Or are you talking about the 2 bigger bolts thats back there besides the 14mm? They look like 19mm or something.
Old Sep 20, 2008 | 08:07 AM
Kwame's Avatar
Kwame
You should be removing a total of three bolts if I remember correctly. One bolt at the top of the caliper to "open" it up and remove the pads(there is also a bolt at the bottom but there is no need to remove that bolt), then another two to unbolt the caliper from the spindle. After the caliper unbolts from the spindle you can then slide it off of the rotor.
Kwame's Avatar
Kwame
Yes, they are bigger bolts.
Old Sep 20, 2008 | 08:09 AM
THe Emperor
OK thanks
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
