Adjusting camber at home
Old Nov 25, 2008 | 09:41 AM
josesantigo57's Avatar
josesantigo57
Default Adjusting camber at home
Does anyone measure their own camber? Ive been thinking of maybe buying a camber gauge? Anyone ever tried one? Thanks.
Old Dec 11, 2008 | 04:36 PM
josesantigo57
Anyone?
Old Dec 11, 2008 | 05:11 PM
Beau's Avatar
Beau
http://www.smartracingproducts.com/alignment.htm
I've never used it myself, but I don't think I would consider it good enough to set it and forget it. Tires are an expensive thing to waste. And if you change your camber, you will also change your toe. I'm sure you can get very close with the string alignment, but I'd still take it to a place with a Hunter machine once i'm satisfied with how it's handling for the most part.
Old Dec 12, 2008 | 08:56 AM
Q45tech's Avatar
Q45tech
Simple high school Trig problem, measuring and calculating camber and translating in fractional inches of angular offset.
1/8" is ~~ 0.5 degrees
Old Dec 16, 2008 | 09:52 AM
Chebosto's Avatar
Chebosto
the electronic smart camber tool is great, as long as the floor you're measuring on is completely LEVEL.
i've used it before and works great.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
