Will the 350EVO anti roll bars work with the Borla Dual?
When the bars first came out and they showed pics of the rear bar. It was specifically pointed out that it was shaped for dual exhaust's in mind on purpose.
In fact here's a pic of the bar on the car and you can clearly see it will clear dual systems.
Here's the thread the pic came from
https://my350z.com/forum/showthread....50Evo+sway+bar
QUOTE from 350EVO,
"The 350EVO rear bar is a different design than most..... as we have done away with the nasty bends the OEM bar has. The stock (OEM) bends take away from the torsional deflection rate and or the accuracy of a sway bar. (with this design you can run a smaller diameter bar and have a higher deflection rate.)
We were the first ones to run a true dual exhaust and also took this into thought when the bar was designed."
QUOTE from 350EVO,
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
