Those with Ichiba Camber Arms
Old Feb 9, 2009 | 03:06 PM
josesantigo57's Avatar
josesantigo57
Default Those with Ichiba Camber Arms
I installed the Ichiba front camber arms. They went in great. However when i took the car to get aligned they would not go beyond -2.5 camber when on the website they say they will reach up to -3.75.
Any ideas, suggestions? Thanks.
Old Feb 9, 2009 | 09:34 PM
aloh's Avatar
aloh
wow what kind of wheels are you fitting to need over -2.5??
Old Feb 10, 2009 | 02:49 AM
josesantigo57
Im runing 18x9.5 +20 with 275s but i just need the camber for the track. Anyone have this problem?
Old Feb 10, 2009 | 08:30 AM
Gsedan35's Avatar
Gsedan35
Ideal camber is not set by copying what someone else is running, it's what you set to based on you taking tire temp spreads with a tire pyrometer across each tires surface until you get the averages closer to where they should be. Otherwise your just crossing your fingers that your actually getting more of the tire involved.
http://www.longacreracing.com/articles/art.asp?ARTID=16
Old Feb 10, 2009 | 09:01 AM
josesantigo57
Thank you very much, I know this already. I want to take temperatures starting off at -3 camber.
Can someone help me with my actual question?
Old Feb 10, 2009 | 09:38 AM
sfarrah's Avatar
sfarrah
Lowering the car more should get you some more camber, otherwise it looks like you need to run a different camber arm. I've had my SPL's down to -3.5 degrees.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
