Rear Camber Kit [ What Brand ? ]
Old Feb 25, 2009 | 11:50 PM
350Z_NOW's Avatar
350Z_NOW
Default Rear Camber Kit [ What Brand ? ]
I need to buy camber kit what brand is good out there?
Old Feb 26, 2009 | 04:57 AM
tsaville's Avatar
tsaville
SPC makes a pretty good one
Old Feb 26, 2009 | 05:10 AM
calin's Avatar
calin
+1, that's what I have
Old Feb 26, 2009 | 09:11 AM
ZRuggernDC's Avatar
ZRuggernDC
Cusco... That's what I have
Old Feb 26, 2009 | 04:58 PM
RRMikey's Avatar
RRMikey
+1 on the spc rear camber and toe kit. works great on mine.
Old Feb 26, 2009 | 06:45 PM
labelworkshop75's Avatar
labelworkshop75
SPL is simply the best. Look at how beefy it is compared to the SPC. SPL has the most positive adjustment for lowered Z's
http://www.splparts.com/main4/parts/...rmultilink.htm
Old Feb 26, 2009 | 09:20 PM
maximariceboi's Avatar
maximariceboi
^+1 on that. As for affordability, SPC is the way to go..
Old Feb 26, 2009 | 09:44 PM
JL350ZSD's Avatar
JL350ZSD
Eibach, made by SPC and a little cheaper
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2890
Old Feb 26, 2009 | 10:15 PM
maximariceboi
^^ Good info. Is there any difference between the two at all?
Old Feb 27, 2009 | 06:05 AM
NismoP10's Avatar
NismoP10
+1 for the SPL. It might cost a little bit more but it's a quality piece.
Old Feb 27, 2009 | 06:48 AM
JL350ZSD's Avatar
JL350ZSD
Nope, its a SPC camber kit in an Eibach box.
Old Feb 27, 2009 | 11:21 AM
350Z_NOW's Avatar
350Z_NOW
when I install it, will the shop do the alignment? because I've heard that shops don't align lowered cars.
Old Feb 27, 2009 | 04:04 PM
JL350ZSD's Avatar
JL350ZSD
I don't see why they wouldn't. I didn't have any issues. Go to the regional section and ask where the best place is in your area.
Old Mar 1, 2009 | 03:51 AM
definitionxmk's Avatar
definitionxmk
For true coilover setup... get the camber and toe arm kits. battle version is usually the ones that make the list. myself, i went with wicked tuning rear and toe arms... works great.
but on a budget and maybe just on springs.... SPC rear camber & toe bolt kit.
hope that helps =)
Old Mar 1, 2009 | 10:32 PM
maximariceboi
hope that helps =)
Cool. Thanks for that info. What's your say on these circuit sports rear traction trailing arms? I'm planning to purchase them.
Also for springs, would I need aftermarket front arms to fix the camber?
Thanks.
Old Mar 1, 2009 | 10:33 PM
maximariceboi
Wow ic. I guess I'll be getting a set of these for now.
Old Mar 7, 2009 | 02:17 PM
350Z_NOW's Avatar
350Z_NOW
If i buy the camber arms do i need the toe bolts as well?
camber arms picture
<center>
<a href="http://s16.photobucket.com/albums/b41/DINOL/?action=view&current=AK001_2.jpg" target="_blank"><img src="http://i16.photobucket.com/albums/b41/DINOL/AK001_2.jpg" border="0" alt="Photobucket"></a><br /><br />
</center>
Old Mar 7, 2009 | 04:36 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
camber arms picture
<center>
</center>
to do it correctly, yes, you need both
which is why the Eibach/SPC kit is the most widely used - it's not expensive and it comes with everything needed, and does the job well
Old Mar 7, 2009 | 05:59 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
+1 on SPC they are good
Old Mar 7, 2009 | 06:10 PM
AdriaN-'s Avatar
AdriaN-
I went with the intensepower rear camber links and SPC toe Bolts.
