Big brake kit for non brembozzz
Old Apr 17, 2009 | 08:44 AM
TopNotch's Avatar
TopNotch
Default Big brake kit for non brembozzz
has anyone tried this??
http://www.racingbrake.com/350Z_non_...1-311-0-01.htm
i think its pretty good for the money, for the same size rotors just 1 piece, is only $650.
Old Apr 17, 2009 | 09:06 AM
EDIT: My bad. I thought you were asking for opinions.
Old Apr 17, 2009 | 09:12 AM
Jeff92se's Avatar
Jeff92se
Originally Posted by davidv
I see little point in spending $2,000 and simply relocating the OEM calliper. What did $2,000 get you? Rotors and pads?
Where do you get $2,000?
For $1,027.26, you get upgraded 2pc rotors(about 0.5lbs lighter than the small 11.5" oem rotors), pads and the relocation brackets. One can upgrade to bling calipers at a later time also
MSRP: $1,208.52
Sale Price: $1,027.26
You Save $181.26!
Part Number: 2001-311-0
Side: L/R
Position: FRONT
Size: 332x24mm (13.1" x 0.9")
Rotor Weight (lbs.): 14.4
Old Apr 17, 2009 | 09:37 AM
Spork's Avatar
Spork
For that much... why not go with an actual BBK?
Old Apr 17, 2009 | 09:49 AM
TopNotch's Avatar
TopNotch
where did you see anything on that link for $2,000??? i saw $1050 for the 2 piece rotors and caliper mounts, and 600 for the same thing except with 1 piece rotors instead 2 piece...
Old Apr 17, 2009 | 09:58 AM
freedonutss's Avatar
freedonutss
Why not get the brakes that come with the sport pkg 370z? There $1200 and they come with everything you need.
Old Apr 17, 2009 | 10:02 AM
TopNotch's Avatar
TopNotch
havent seen those yet, i'll look into 'em.
I just like this kit, because for 1,000 bucks i can get up to 13" rotors, 2 piece, and slotted, with decent pads, not bad imo, and if i didnt want 2 piece, i could at least get the kit with the 1 piece rotors (still 13"), pads and brackets for only $650...
Old Apr 17, 2009 | 10:11 AM
Jeff92se's Avatar
Jeff92se
Because for that price you get rotors that weigh 26lbs vs 14.4lbs.
Old Apr 17, 2009 | 10:13 AM
Jeff92se's Avatar
Jeff92se
Such as?
Old Apr 17, 2009 | 10:19 AM
freedonutss
Ok so the rotors are 12 lbs heavier.... I wonder which one will outperform which on the track(for the price)? Tough one.
Old Apr 17, 2009 | 10:23 AM
Jeff92se's Avatar
Jeff92se
All the brake fade and the bonus of 10+ lbs of unsprung weight on each front wheel.
http://www.edmunds.com/apps/vdpconta...7/pageNumber=1
We've noticed that the brakes in modern Hondas tend to wilt at the first sign of hard driving, yet the TL's brakes buck this trend. They haul the Acura to a halt from 60 mph in a scant 106 feet. This performance is matched by the G37, but the TL exhibits less brake fade than the Infiniti. Perhaps this marks the turning of a new leaf for future Honda offerings.
Old Apr 17, 2009 | 10:27 AM
TopNotch's Avatar
TopNotch
12lbs per rotor difference is a good amount, i'd have to go with the 2 piece over the 370 sport kit.
Old Apr 17, 2009 | 10:40 AM
Kwame's Avatar
Kwame
We installed the rear kit on Adam's car...
Edit: Just realized that this picture was prior to the install.
Old Apr 17, 2009 | 10:42 AM
Jeff92se's Avatar
Jeff92se
When you guys mix/match these BBK parts, do you do the front/rear bias calculations?
Old Apr 17, 2009 | 10:49 AM
Kwame's Avatar
Kwame
Well the Endless front kit is designed to work with either any of the Endless rear kits or either one of the rear OEM setups (Brembo/Non-Brembo). The Racing Brake rear kit is more a big rotor kit than it is a BBK since you are still using the same rear stock caliper, so therefore the bias has not changed.
Old Apr 17, 2009 | 10:53 AM
tonyrd1's Avatar
tonyrd1
Intersting, subscribed for more information
Old Apr 17, 2009 | 10:59 AM
cdoxp800's Avatar
cdoxp800
You know you could always get a real BBK for around 2k
Full Kit: $1,995.00
http://www.conceptzperformance.com/C...173.17.159.246
Just the Fronts: 1,200.00
Just my
Old Apr 17, 2009 | 11:01 AM
Jeff92se's Avatar
Jeff92se
IMHO, if you use a bigger (than oem) rotor, that will change the force applied and therefore change the front/rear bias. Whether or not it changes it significantly more then let's say an oem rear Brembo setup is probably what you are getting at?
If adding a rear bbk setup didn't change the bias (hopefully for the better), I'm not sure why it was done? Only for cosmetic reasons?
Old Apr 17, 2009 | 11:14 AM
Kwame's Avatar
Kwame
No, you are correct. Changing the rotor size does change the brake bias since Torque equates to force multiplied by a moment arm and in this case the moment arm would be increasing due to the increased rotor size thereby increasing the amount of torque exerted which will also thereby increase the rear bias.
The question remains is how much would the rear bias be increasing? I really don't know the answer to this question currently but i'm sure if I sat down I would be able to calculate it since most of the other variables in the equation would be held constant.
As far as our reasoning it was for cosmetic reasons. The front BBK is more than adequate for the very few track days that this car sees.
Old Apr 17, 2009 | 11:19 AM
Jeff92se's Avatar
Jeff92se
If the front BBK increased the brake force at all, then I'm sure the rear bbk addition is an improvement. The owner should be noticing less brake dive, less abs front lock and flatter braking
