2004 350z has factory cambers?
Old Jul 12, 2009 | 07:52 PM
350ZnismoPR's Avatar
350ZnismoPR
Default 2004 350z has factory cambers?
I am curious to know if i can take my car to align my rear wheels. Because since i got the 19 inch rims, the tire has worn out only in the inside corner of the tire. Anybody knows?
Old Jul 12, 2009 | 08:02 PM
Entaille's Avatar
Entaille
it helps with cornering. it is aligned that way for a reason. camber wear sucks, but you can always unmount and swap the two rear tires.
Old Jul 12, 2009 | 08:08 PM
davidc81's Avatar
davidc81
chamber? is this lawchick trolling?
Old Jul 12, 2009 | 08:40 PM
350ZnismoPR
My problem is that the rear tires are wearing unevenly on the inside shoulders. IS there a camber kit to correct this?
Old Jul 12, 2009 | 09:03 PM
davidc81's Avatar
davidc81
any camber kit will solve this. there are at least 20 kits for the Z. i personally use the battleversion arms.
Old Jul 12, 2009 | 09:12 PM
350ZnismoPR
thanks man. Will do
Old Jul 12, 2009 | 09:13 PM
Kwame's Avatar
Kwame
It might be possible to get your car back within factory specs with the OEM pieces but your alignment shop would have to be the ones to let you know if that is a possibility.
If you do need a rear camber kit we offer the
Eibach:
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2890
Cusco:
http://www.z1auto.com/prodmore.asp?m...ng&prodid=3037
and SPL adjustable camber arms:
http://www.z1auto.com/prodmore.asp?m...ng&prodid=3969
Just let us know if there is anyway we can assist you or help you out if need be.
lolwatbro
Oct 9, 2021 04:58 AM
416blueZ
Sep 24, 2015 02:11 PM
NYGiants0186
Sep 8, 2015 10:37 AM
